Computers & Internet Logo
A
Anonymous Posted on Sep 17, 2014
When pressing message link in microsoft outlook to put on internet chrome shows the following Failed to read the configuration file. Please contact your system administrator - can anyone help?
Also when trying to get into mozilla firefox as previously instored I am receiving the same message
Randal Lovelace
Level 2:
New Friend:
Night Owl:
An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • Expert 112 Answers
  • Posted on Nov 25, 2014
Randal Lovelace
Expert
Level 2:
New Friend:
Night Owl:
Answers
112
Questions
0
Helped
24295
Points
214
Outlook emails only work with IE on the 'web server' - you could install and use a mail fetching program (which is what Outlook actually is), or you can use IE to fetch the mail.
5 Related Answers
Anonymous
  • 2841 Answers
  • Posted on Aug 04, 2009
SOURCE: Clicking on links in email don't work
Links in an email in the Junk folder will never work. It is set this way to protect you. However if you are clicking a link in an email in the Inbox, right click the link and then click "Open Hyperlink". Once you do that the links on emails in your Inbox should work from now on. If not, is IE your default browser? If not make it so. If that does not work open Internet Options >> Control Panel >> Programs Tab >> Reset Web Settings.
Anonymous
  • 838 Answers
  • Posted on Apr 11, 2010
SOURCE: Microsoft Office Outlook problems
Please try these below.
Go to Run, Type Outlook.exe /resetnavpane and press OK....
Let us know the result.
Thanks for joining us.
Good Luck
Testimonial: "Thanks a lot. Solve first time."
Anonymous
  • 1098 Answers
  • Posted on Sep 12, 2011
SOURCE: On trying to access any
Hi there.
Does this only happen when you click the unsubscribe link from email? What about opening the browser directly?
Please let me know.
Thanks.
Mike
  • 4383 Answers
  • Posted on Dec 31, 2013
SOURCE: how do i check if I have mozilla-firefoz on my computer.
Well William, you did not specify what operating system you have. My guess is Windows. If you have Vista or 7, press the start key and type firefox. Look under all programs.
cirocpatel
CIROC TECH SUPPORT
  • 524 Answers
  • Posted on Mar 13, 2014
SOURCE: I am continuing to recieve Windows update error 9C48 and I am unable to fix error
http://www.microsoft.com/download/en/details.aspx?id=23332
Instructions:
  1. Uninstall IE9, if you already have it installed, and restart the computer.
  2. Download the installer.
  3. Disconnect from the internet. This is important because the installer attempts to download the latest, bad binaries from Windows Update.
  4. Let the install finish, and restart.
  5. Reconnect to the internet and check Windows Update. If all went well, you should be able to see the Cumulative Update for IE9, instead of IE9 itself.
Thanks
Testimonial: "Chirag Patel. Thank you for your reply. May I please ask additional help on the IE unistall? If I go to About internet explorer, my computer states I have IE11, however I have no IE11 update installed. The last IE update I have is for IE10. IE9 came pre-installed on my computer at purchase. If I go to uninstall IE9, will that also get rid of IE10, and correctly set the right version of IE on my computer? One mistake I made was to select to upgrade to IE11 via Yahoo when asked. When I now open IE, the desciption now reads, IE provided by Yahoo. Will the unistall of IE9 remove all residual files of any updates not related to IE9, and also freeing up that disk space? Thank You sincerely."
1helpful
Outlook Express 6 - Address book failed to load
The WAB file may have become damaged or corrupted causing one or both of the above error messages. You will need to rename the existing .wab file and restart Outlook Express(OE). Once started, OE will create a new .WAB file. Microsoft does not recommend that you import the data from the old, damaged .wab file. If you do, you may import the damage into the new .wab file.
1. Click Start, point to Find (Search on Windows 2000 or newer operating systems), and click For Files or Folders.
2. In Search for files or folders named, type. *.wab and click Search Now.
3. In the Search results window, Right-click the file(s) with an extension of ".wab" and then click Rename.
4. Rename the file extension (the three left-most characters in the name) to "old" and press ENTER.
If you are still experiencing the issue after applying this fix you can try Address Book Recovery http://www.oemailrecovery.com/address-book-recovery.html
When trying to go to firefox or upgrade/download it shows the following message (also showing when I try to link in outlook 2007)Failed to read the configuration file. Please contact your system admin
Uninstall Mozilla Firefox like you normally would and then you need to go DELETE THE FOLDER for Mozilla under C:\Program FIles\ to make sure EVERYTHING is gone. Then try re-installing Firefox again and let us know.
Using microsoft xp and put my contacts in different categories, family,work,etc. when i sync my iphone the contacts on iphone show up only as contacts. a friend was able to to this but is usin mac...
Hi Eldonj125,
This is a common issue with the iphone. Now, while although it is easy to presume that the issue you ae facing might be due to Operating System Incompatibility (as you probably would've gussed by now), please try the following solution below to see if it helps resolve your situation:
Total outline of the solution:
  • Set Outlook as default program
  • Open Microsoft Outlook
  • Click on Tools >Options and click on Others
  • Check the box Set Outlook as default program for messaging, contacts and calendarClick on OK
  • How to do it:
    • Click on the Start menu and choose Set Program Access and Default,
    • In the left pane, select Set Program Access and Defaults and Select Custom
    • Then Choose a default mail program, choose your Outlook messaging
    Settings on I Tunes
    • Once you are set with the configuration, open iTunes, proceed with the following:
    • Click on iPhonein the left menu
    • In the right window, select the "News"
    • Then, select items to synchronize
    I hope the above information helped. Please do let me know if there are other queires regarding this. Also, pls remeber to vote for me if you find this solution useful. Thank you.
    Regards,
    Technomancer
    6answers
    Can't run outlook 2007
    Try opening Outlook from run command window
    Start > Run > Outlook /safe
    If it works fine close outlook
    Go to following registry HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Office\Outlook\Addins
    HKEY_CURRENT_USER\Software\Microsoft\Office\Outlook\Addins
    Delete the addin key from the regitry
    Happy computing :)
    1helpful
    I can't update microsoft outlook connector, I opened microsoft outlook and it requires this update.(I use this to read my hotmail messages on outlook) The error message from microsoft outlook connector...
    Try to update it in safemode (press F8 at bootscreen until "Start in safemode shows, safemode with network if you dont have the update-file on your computer).
    Or you press ctrl+alt+del and klick the process-tab. When you have all running processes shown, try to find which one is for Outlook and turn it off.
    I don't use outlook so I don't know the name, but try the ones you think, worst thing that can happen is that you have to restart your PC.
    3answers
    How do I acces an pst file with te email that comes with Window Vista?
    You need to download or open the attachment file with the PST file.
    You also need to have Microsoft Office Powerpoint installed on your computer.
    If you do not have office you can download the following software to view PST: Download details: PowerPoint Viewer
    3answers
    Outlook related issues
    did you add the PC in trusted mode at your phone? Activate the contacts sync with your email which configured at the phone and add the same email account in your outlook. All contacts will be synced automatically.
    2answers
    HOW DO I FIX THESE ERROR MESSAGES?
    you need to run a inbox repair tool.
    Make sure you close outlook
    Start > My computer > Tools > Folder options > General tab click on show hidden files and folders > Apply ok
    Go to the follow wing location to find scanpst.exe
    if you are using Outlook 2007
    C:\Program Files\Microsoft Office\Office12
    If you using Outlook 2003
    C:\Program Files\Microsoft Office\Office11
    Double click on SCANPST.EXE
    Click on browse go to following locaiton where your pst file as been save
    C:\Documents and Settings\Robyn M. Drothler\Local Settings\Application Data\Microsoft\Outlook\outlook.pst
    Click on start > then click on repair
    Grand Canyon Tech
    Grand Canyon Tech
