Saddlemen SaddleStow Sport Bike Top Pack For Kymco Scooters 150cc And Larger - X04-05-073 Logo
A
Anonymous Posted on Sep 17, 2014
I hit the starter button while it was running heard a noise now it wont start i hear the starter whizzing but does not engage er start
Its a kymco peoples 504t
Claude Kayser
Level 3:
Top Expert:
  • Master 9,098 Answers
  • Posted on Jan 13, 2016
Claude Kayser
Master
Level 3:
Top Expert:
Answers
9098
Questions
0
Helped
5067829
Points
28436
Gear replacement needed
1helpful
2answers
Starter spinning freely but wont engage engine to start if it did it starts up fine.
Sounds like your pinion/bendix gear is not reliably extending fully to engage the flywheel. There are three common causes of this: (most common) Dried up grease or dirt on the threads of the starter shaft and the pinion/bendix. Failing overrunning/one-way clutch in the bendix
replace starter.
3answers
2001 Sportster. Why does it make a whining noise as though starter is not engaging?
please add more details to your issue> like does the car engine run when you hit start ?
Why wont Kymco MXU 250 start? just a loud high pitched noise is heard
Geez dont keep spending money if your not sure. It sounds like your starter is not throwing in far enough to engage with the ring gear. Please do your hip pocket a favor and get an auto technician to check it before buying a new starter as well. You can also remove the starter and check the gear to make sure its not worn as some are plastic.
On start up there is a noise sounding like something is engaging
Nothing should engage when the engine starts running. The torque converter and transmission pump will spin faster, but not make noise. If they do it wont go away. If the noise is there as the engine start running on it's own. I would guess it is the starter bendix not disengaging after you let off the key. This would entail a new starter. Beings that you have a 98, you might be able to get just the bendix. But you have to take the starter apart to replace it. It's what push the gear forward.
1helpful
Riding in 4 gear starter engaged
your sarter is toast. maybe accidentally hit the button while riding or corrosion in the switch made the connection. Nonotheless, you need a new sarter.
Jet ski wont crank
test voltage at the starter while pushing start button. its also possible that the factory ignition kill is activated, try holding up the lanyard button and repeatadly hit the start button if the alarm is engaged then you should hear the starter barely kick every couple of seconds so then just unlock it. and last and certainly the most common, starter solenoid, they go bad all the time. be sure to check your fuses first though.
Aug 24, 2012 • Water Sport
Where is starter on a gpz750
The starter is under a cover on the left side of the motor. Just behind the cylinder head.
If you hear a clicking noise when you go to start the bike with the starter not engaging. Then its probably the solinoid.
It is under the left side cover by the battery. It is round with two heavy gauge wires running to the top of it. Tap it with a handle of a screwdriver a few times then hit the start button.
Mar 18, 2012 • Motorcycles
IV A PROBLEM WITH MY 91 SUZUKI DR 650 I JUST FITTED NEW STARTER CLUTCH AS I THOUGHT THIS WAS MY PROBLEM BUT IT ISNT,WHEN YOU HIT THE START BUTTON TO START THE BIKE THE SPROCKET BEHIND THE FLY DOESNT SEEM...
Sounds like your starter solenoid is not engaging. Try tapping it with a dead blow hammer or a hammer and block of wood (gently! Not to hard!) If it bumps over that is your problem. Also check all connections to solenoid and starter.
The whirring noise you are hearing is your starter motor but your bendix gear is not engaging.
Hope this helps!
Rob
3helpful
2answers
Electric start not working
i want a speedometer for kymco hipster 125, 03 and handlebars but i cant fine any, could you tell me please.
Top Saddlemen Cycling Experts
ADMIN Andrew
ADMIN Andrew
Kardoc
Tony Parsons
Tony Parsons
Are you a Saddlemen Cycling Expert? Answer questions, earn points and help others
