SIMPLE DAY/NIGHT TIMER. which SPOTS ARE SET UP DAY, WHICH FOR NIGHT???
Http://waterheatertimer.org/How-to-set-timers.html
Actually the timer dial can be either day or night, but usually the dark background with white numbers is 6 pm to 6am (night time)
While the white background with dark numbers is 6 am to 6 pm (daytime)
Gene
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
SOURCE: how to set fm/1 stuz-l timer instructions
The timer works just like a lamp timer. First set it up on the correct time (white arrow on the inner circle). Next push the 15 minute increments down when you want the heater to run.
SOURCE: How to set start time on timer raindrip r672c
The start time on these style of timers is whenever you set it. So if you want it to run at night it needs to be set at night, e.g. turn to off/reset, then at 10pm go set to the freq. and duration desired, then it will run at 10pm. Also note this timer waits a full cycle to run the first time after it is set, e.g. if today you set it to run weekly, the first time will be next week.
SOURCE: I just bought a house with the Night Sentry EJ351
Here are the instructions:
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/ej351c%20-%20english.ashx
You will have to pick the times you want the lights to go on and off.
SOURCE: how do I set my R672C Raindrip timer
http://www.raindrip.com/information/catalogs-and-manuals
http://www.raindrip.com/images/stories/pdfs/R672-single-timer.pdf
SOURCE: Set up Intermatic outdoor timer 7day/7event
I have misplaced and forgot how to set a Model HB65R timer, can you help, thanks, Murray
