Yardworks Broadcast Spreader Walk Behind Logo
A
Anonymous Posted on Sep 16, 2014
What is the setting for lawm fertilizer on a yardworks broadcast spreader
Model Number TC2026
Valerina Stefan Jeffries Morgan
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Sep 17, 2014
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
2157
Points
Yardworks 85 lb. Capacity Tow Behind Broadcast Spreader. Where can I get the wheel bushings for a 85 lb. Yard Works tow behind spreader please?
question edited for clarity.
Here are the wheel bushings / bearings
Yardworks® 85 lb. Capacity Tow Behind Broadcast ...
Menards https://www.menards.com > tools > atv-accessories > y...
These replacement axle bearing are for the Yardworks 85 lb. Capacity Tow Behind Broadcast Spreader: BS0001-N. Includes: (2) axle bearing.
US$19.99
Sep 07, 2023 • Garden
I think the spreader I have is from Agri-Fab - It is an 85lb PreciseFit Broadcast Spreader, and I was hoping to get a cross-reference with a Scotts spreader for the settings (which all seed/fertilizer/lime...
Hello Assaidca,
I suspect it is about the same as any other comparable spreader. These things really are not calibrated to any universal standard.
You can download manuals directly from the Agrifab website however by clicking on the provided link and looking for your specific model number under the spreaders link:
Downloadable Manuals
I trust this information has proven useful.
1helpful
2answers
I have scott drop spreader and I want how it will setting for fertilizer
Check the fertilizer bag for instructions. It will tell you the number to set it at for a drop spreader and a broadcast spreader.
4helpful
5answers
Republic EZ broadcast spreader...what number to use when lining up the mark to calibrate the spreader...lost the instruction book
Hello, to solve your question about what number to use to calibrate your broadcast spreader, please use the step-by-step instructions below:
1. If you don't already know the square footage of your lawn, please walk off or measure, multiplying the length by width. For example, my lawn is 100 ft wide by 100 ft long; this equals 10,000 sq. ft.
2. Use this figure (30,000 sq ft) to determine how much fertilizer, insecticide, fungicide,apply etc., to purchase and apply.
3. To calibrate the spreader for applying your product at the correct rate, first weigh and hold out an amount of product to cover a pre-determined test area; for example, enough for a 200 sq ft space.
4. Because most lawn fertilizers are packaged to cover areas in 1000 sq ft increments, it's easy to figure how many 1,000 sq ft applications you need for your lawn.
5. Set your spreader to 3 and measure 1/5 of the recommended application on your product, to cover a 200 sq ft area.
6. Use your spreader to cover this 200 sq ft area.
7. If there is product remaining in the hopper after walking this 200 sq ft area, increase the setting number and move to another test area, repeat steps 5 and 6.
8. If there wasn't enough product to cover the test area, back the number down, move to another test area, and repeat steps 5 and 6, until you finish with product and lawn test area at the same time.
9. Remember to never leave product in your hopper because many chemicals are corrosive and can destroy the moving parts, making the spreader inoperable.
I hope this helps!
Apr 02, 2011 • Garden
4helpful
I buy Scotts fertilizer and use an earthway broadcast spreader.
add 10 - Scotts Turfbuilder spread at # 4 on a Scotts spreader should be on setting # 14 on an Earthway spreader.
Top Yardworks Garden Experts
Jay Finke
Jay Finke
john h
Are you a Yardworks Garden Expert? Answer questions, earn points and help others
