Kingston (DTIU3/2GB) 2 GB USB Hard Drive Logo
Posted on Jul 03, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
USB Device Not Recognized in winxp(kingstone 2GB USB2.0 DATA TRAVELER)
Brian Sullivan
Level 3:
  • Kingston Master 27,725 Answers
  • Posted on Feb 05, 2012
Brian Sullivan
Kingston Master
Level 3:
Answers
27725
Questions
Helped
5664256
Points
79191
Click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts
if you need more help with this post a reply
hope this helps you
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jul 11, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
530
Points
Hi i have 32 gb kingston pen drive it works in office laptop but when i use it at my home pc then it is not detected,serial number 39621564014D581
1helpful
Kingston 2gb datatraveler malfunctioned
there is absolutely no problem in your pc .
your pen drive is faulty.
2answers
USB 2GB KINGSTON DATA TRAVELLER HANGS MY LAPTOP
USB KINGSTON CAN'T ACCESS TO MY LAPTOP.HOW CAN SOLVE MY PROBLEM.
Usb flash drive not recognized when plugged into...
I had problem of not detecting the Kingston 2GB pendrive in my Vista Ultimate. I just plugged the device and did a restart, and went to device manger located the yellow colored part right clicked and opted for update the driver and selected the windows to do automatically after several minutes the device became ready to use :-)
2answers
Usb flash drive not recognized when plugged into hub
data is lost,
test with H2testW'
fix with PD V1.08 B3
good luck !
Flash drive can not be detected when installed on a desktop with an XP operating system. flash drive is recognized on several other desktops with XP, but not my computer. is it a driver issue? if so, can...
Hi john_nelson0,
First check the other USB ports. Try it in the USB ports on the back of the computer. If that doesn't help then make sure you have the latest WinXP service pack installed. Although it is possible to have a problem with the drivers, they are built into Windows and are not available for download from Kingston. Do any other USB drivers work on that computer?
Kingston Tech Support
Driver needed for 2gb kingston usb
If it is Win XP with SP1 ( check this - tight click My Computer, click Properties and check if it is Service Pack 1), then you need the latest SP from microsoft (that is SP3).
WinXP not recognizing USB drives, the SP is the most common cause I  have seen. Update to SP3 and it should solve your problem.
HTH,
Deboo
USB device not recognized
Recent virus, trojan or SP update may have hosed your driverset.
Get new one here: http://www.softwarepatch.com/utilities/kingston-traveler.html
Kingston DT100/2GB Detection and Failure
No need to worry, I will solve your problem follow this link to find how to solve it http://www.fixya.com/support/r4391734-usb_flashdisk_pen_drive_write_protect or you can see my blog, http://adhiwahyudy.blogspot.com, but this blog use indonesian languange
Usb not recognized?????????
The USB port in which your flash disk has been inserted muight be damaged. Try inserting it in another port.
Top Kingston Computers & Internet Experts
Jean Thiebaux
Are you a Kingston Computer and Internet Expert? Answer questions, earn points and help others
