I can no longer receive e mails on my Blackberry since my provider changed to BT Mail
SOURCE: Blackberry Pearl Message Inbox
Go to message>options>scroll to bottom and you can separate your messages via theme control select and it will allow you to change your message boxes.
SOURCE: How do I setup my Voice Mail for the first time?
all you have to do is ring your service provider they will do it over the phone(activate it) then give u a number to ring to do your message too others and check the mail
It depends on your carrier, but you should be able to hold down the 1 key and it should connect you to your voicemail box and there should be setup info there.
SOURCE: How to manage BlackBerry Curve 8330 calendar from home PC desktop
The blackberrys link to outlook and not their own calendar/contact manager. If you have outlook at home, you should be able to use the desktop manager software to sync with that.
SOURCE: I need to remove yahoo mail from my blackberry
The smart thing to do before you return the phone is to do a wipe handheld. You can find the wipe handheld option if you go to your menu -> options -> security options -> general settings. Here you can press the blackberry key and choos wipe handheld. When you do a wipe handheld all data on the phone is erased and the phone is ready for the new user. Make sure that you choose delete 3rd party applications also.
best regards
