Question about Kaz Humidifiers
How do I remove hard water buildup from plastic water reservoir in my humidifier
I have tried vinegar but does not appear to be working
5 Suggested Answers
SOURCE:
SOURCE: Humidifier stopped working after cleaning.
It started working again on its own. Not much of a solution!
I think some water must have got into the electronics and then once it dried, the humidifier started to work again.
Christiaan
Posted on Feb 08, 2008
SOURCE: Cleaning water tray
I usually just balance the tray upside down on top of the base and fill the edges with vinegar. You could also put the the tray in a bowl filled with vinegar and submerge the whole thing.
Posted on Jan 18, 2009
  • 4736 Answers
SOURCE: I own a model SA-1015
You can order parts directly from Clarion at the following link
www.clarion.com/us/en/support/ordering_parts/index.
Juts have your Model # and Part #, if you know the part #.
Posted on Feb 04, 2011
  • 5 Answers
SOURCE: Wont blow out mist
it has a quiet operation when you got it brand new did it put out mist
Posted on Nov 02, 2012
It runs but does not put out any mist.
You didn't specify the brand or model, but for generic advice, try using a strong solution of white vinegar and water and soak overnight or for several days (if very scaled up).
If you were using hard water in the humidifier, try using a commercial humidifier cleaner such as BestAir products (or similar - there are many to choose from): Amazon com BestAir 3US 6 UltraTreat Ultrasonic Vaporizer Water Scale...
(Make certain it's certified for steam and/or ultrasonic use, if your using that type of humidifier).
Follow directions on box. You will have to let soak for a period of time (hours/days) to allow chemicals to do their thing.
If you are using "soft" conditioned water, just refill with soft water and allow to sit for several hours, then discard and refill. The hardened minerals will re-disolve and will be removed when you flush the unit. For hardened minerals clinging to the sides, etc, just use your fingers to break up, possibly a brush or Dolby pad and break them loose.
(Soft water has just as much minerals as hard water, but in hard water there are mostly calcium based and turn rock hard and in soft water they are sodium based (sodium bicarbonate actually) and have a weak structure).
It's important to keep a humidifier clean of deposits, not just to keep the unit running, but to avoid air quality problems (bacteria will cling to scale buildup, which make excellent breeding grounds for them).
If you use "hard" tap water, clean (at a minimum) once a week. Use white vinegar and water - 50/50 mix. If your using "soft" conditioned water, clean once a month. Same with distilled water.
You could also consider using a small amount of bactericide in the water to prevent bacteria from growing. (Okay for filter type humidifiers, but DO NOT use in ultrasonic or vaporizer type humidifiers). 1/4 cap full should suffice. BestAir 3BT 6 Original BT Humidifier Bacteriostatic Water Treatment 32 oz
Jan 03, 2016 | Humidifiers
How can I prevent mineral buildup in my small humidifier?
You really have an mineral problem. I have pretty much same here. I only use bottle water that comes in gallon size from grocery. Ot is the only way I have found other than constand cleaners or a water softener. Good luck
Jan 27, 2015 | Holmes Products Humidifiers
True Steam Direct Injection Model # HM506 service light blinks 6 times before remaining a solid color. What does that mean? I realise that the unit is detecting a system fault, would just like to know...
Remove and clean the water level sensor and see if this resolves your error. If cleaning doesn't do it, check the connector for buildup. If neither of the above works, you'll need to order a new sensor - I've gone through two in four years as the heat appears to crack the plastic housing, allowing water to wick up between the plastic and the contact, ultimately shorting it.
Feb 21, 2011 | Honeywell Power Humidifier: Furnace...
Spitting noises and gushing water
Another alternative to vinegar is to use lemon juice. About 1 cup to a tank of water should do the trick. It smells much better than vinegar and also has the acid content to clean the vaporizer.
Jan 18, 2010 | Vicks Warm Steam Vaporizer 1.5 Gallon...
Hunter Humidifier #33222
From The Hunter Manual
1. Turn the humidifier ‘OFF’ and unplug the unit.
2. Lift the main housing and remove the water dispersion tray and the PermaWick™ Filters. The motor is attached to the main housing. Do not place the motor near water. Do not use a wet towel on the motor or motor housing as electrical shock may occur.
3. The PermaWick™ Filter should be cleaned in a vinegar and water solution to remove any mineral buildup. Place in a solution of one (1) gallon of water and eight (8) ounces of undiluted white vinegar. Allow the filter to soak for 20 minutes.
4. After soaking, rinse it several times with clean water. Place the PermaWick™ Filter in a location where it can drip dry while you clean the other parts of your humidifier.
5. Remove the water tank from the base and empty any water that is left in the tank. Soak the base in a mixture of one (1) gallon of water and eight (8) ounces of vinegar for 20 minutes.
6. After soaking, wipe the base with a soft cloth or sponge to remove any mineral build up. Rinse with clean water several times. If you are planning on storing the humidifier, be sure the base is completely dry.
7. Fill the water tank with one (1) gallon of water and eight ounces of undiluted white vinegar. Replace the tank cap and shake the tank vigorously until all interior surfaces of the tank have been exposed to the water/vinegar mixture.
8. Empty the tank of the water/vinegar mixture. Rinse it several times with clean water and then replace the tank cap. If you are planning on storing the humidifier, dry it inside and out, leaving the cap off to allow the tank to completely dry. Continue to clean the other parts of your humidifier.
9. Remove the water diffuser cap by squeezing the two tabs as shown in Figure 3. Rinse the cap in clean water to remove any debris. If the cap contains hard water residue, soak it in a mixture of one (1) quart of water and two (2) ounces of vinegar for 20 minutes.
Rinse well and reinstall the water diffuser cap. Do not expose motor or other electrical components to water.
10. Wipe the surfaces of the main housing with a soft cloth.
11. Once all the parts are clean, reassemble the humidifier, and follow the USING YOUR HUMIDIFIER to continue use. If you are storing the humidifier, make sure the parts are completely dry, reassemble, and store in a dry location
Jan 16, 2009 | Hunter CareFree Plus 33222 Humidifier
How do I clean Hunter Humidifier #33222 ?
From The Hunter 3322 manual.
9. Remove the water diffuser cap by squeezing the two tabs as shown in Figure 3. Rinse the cap in clean water to remove any debris. If the cap contains hard water residue, soak it in a mixture of one (1) quart of water and two (2) ounces of vinegar for 20 minutes. 41553-01 01/03/2008 6 © 2008 Hunter Fan Company
11. Once all the parts are clean, reassemble the humidifier, and follow the USING YOURHUMIDIFIERto continue use. If you are storing the humidifier, make sure the parts are completely dry, reassemble, and store in a dry location
Not adding moisture to the air
Have you cleaned the unit lately? The following is from the owners manual.
Jan 04, 2009 | Hunter CareFree Plus 33222 Humidifier
I need to know how to clean my filters on Hunter Humidifier Model # 33222. I have misplaced my instructions.
The instruction manual suggests using the water vinegar solution.
The following is from the manual.
11. Once all the parts are clean, reassemble the humidifier, and follow the USING YOURHUMIDIFIERto continue use. If you are storing the humidifier, make sure the parts are completely dry, reassemble, and store in a dry location.
Dec 18, 2008 | Hunter CareFree Plus 33222 Humidifier
Humidifiers Logo
Top Kaz Humidifiers Experts
ray gallant
ray gallant
Tom Chichester
Are you a Kaz Humidifier Expert? Answer questions, earn points and help others
