SOURCE: I have water coming from the bottom. How do I take
remove the 2 bottom front panel screws-mike
SOURCE: kenmore elite 3t washer with code f71
The F70 and F71 error codes on this model of washer indicates a communication problem between the user interface control board and the central control unit (main control board). These error codes can sometimes be caused by a power surge or glitch through the electrical lines. Try unplugging the washer to completely disconnect electrical power. Wait 1 minute and then plug the washer back in to the see if the fault code clears. If it does, then the washer may work normally.
If the code reappears, then you could have a wire harness connection problem, a failed user interface control board or a failed central control unit. I recommend calling a service technician to properly diagnose and repair this type of problem so that the correct component can be replaced.
Be sure your unit is plugged into a 3 prong grounded outlet as well.
F71 is a "heatbeat failure" which means that your front interface control board is shorted and will need to be replaced. it's actually fairly easy to replace and can definitely be done by yourself. To access the part, just pull the unit forward and remove the 3 screws coming in from the back of the top panel. Remove the top panel by pulling it back, up, and off. Then remove all the screws going into the top of the control panel. Remove the dispenser drawer and remove the screws coming in through the dispenser. Remove the screws coming from the inside of the dryer going forward into the control panel, then remove the control panel (it's just clipped in on the bottom. After that you can disconnect the wire harnesses to the front interface control board and replace that part.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
SOURCE: amana front load error code
Hello & Welcome
to FixYa F70 is a communication error which is caused when no communication
is detected from the user interface to the CCU (central control unit). Please
check the wiring to user interface and the central control unit, if that is
fine and you can see the drum rotating then replacing the user interface is
recommended repair. If the drum won't turn then the CCU needs replacement.
Please get back to me if you have any other questions. Kevin
SOURCE: amana front load washer error code "nd". Door is
Hello there and welcome to fixya
From what you're describing it sounds like the drain pump is blocked.
The nd error code indicates "no drain". If the unit can't drain it won't
spin. You're going to have to slide the washer out far enough to remove
the rear panel; be careful not to damage the floor. Once you get the
rear panel off you will see the pump. Be sure to have plenty of towels
& a small container to catch water. I am sending you instructions
from the service manual to remove and replace the pump. Another
possibility is the drain line is blocked or something is stuck in the
tub to pump hose.
