How can I adjust the sites on my 22 rifle . it has iron sights and the adjustment is in the rear
Loosen the rear sight set screw with the screwdriver by turning it counterclockwise.
Use your fingers or a punch--it should be brass or plastic to keep it from marring the metal--to tap the sight either left or right as needed.
Tighten the screw back down with the screwdriver to secure the rear sight in place.
Fire four or five rounds with the new sight adjustments to make sure the sight has been adjusted properly. Repeat steps one through three as needed until the sights are adjusted correctly.
