How do you fix fault code 37,016,43 on a xerox printer
There is a bulletin from Xerox that helps to troubleshoot and identify the error. If you provide me your e-mail address I will send it to you. Please e-mail me at [email protected].
SOURCE: xerox printer error code (04,025.46)
This is a print head position issue.
TRY FIRST (Solutions without parts):
1. Check that the wipe mechanism has homed. 2. Check the printhead position and verify that it has initialized properly / manually home the printhead and power cycle the printers power and check for the error to return. If not then the error was most likely due to non-process function (something out of sequence).
Part likely to be the cause:
GEARBOX AND MOTOR,PROCESS DRIVE - PL 4.0, Item 14.
SOURCE: xerox phaser 8400 fault 37,016,43:24800
Sadly that is not good.That normally is one of the heaters in the print head has failed not warming up enough to allow the ink to remain liquid. It frequently is the result of a failure of the electronics module, none of the most likely problems is a cheap fix. I will give you the list of most probable causes.
Wish I had a more hopeful answer.
PARTS:Parts are listed in the order of highest probability for repair.
NUMBER QTY DESCRIPTION
119649580 1 *ELECTRONICS MODULE (STRIPPED)
671529180 1 I/O BOARD
650430300 1 *PRINTHEAD ASSEMBLY
The electronics module. Listed as stripped, means it comes without the ram and nvm boards. When that fails it is a portion of that module that supplies the heater voltage. I think its a 50 volt source off hand.
SOURCE: we have a xerox docucolor 700 and we keep getting
check the belt hole sensor on the accumulator belt for contamination
SOURCE: xerox 5225 fault code 010-320
that is a fuser overheat code suggest you have a techintion repair or replace the fuser
