Can not seem to find to replace old cartridge
Hello, The toner/drum cartridge in behind the front cover. I have put you a website to get a manual that explains where and how to change the toner.
Product Support
Click up there
Please rate my answer, thank you.
Turn off your Epson C900 printer and unplug it from your computer and from the electrical socket. Open the left-side panel of your C900 printer and locate the toner cartridge you want to replace. Epson has labeled each of the four cartridges.
Stick a finger in each of the holes in the empty toner cartridge. Pinch your fingers together and then slide the cartridge out from the printer's interior.
Remove the new toner cartridge from its packaging and shake it vigorously to remix any settled toner. Take the cover off of the new cartridge by lifting it up and out to the right. Slide the new toner cartridge into the empty slot in your C900 printer. Close the left-side panel of your C900.
Manually Removing Toner for magicolor 2400W
1. Hold down the Cancel button for 10 seconds or longer.
2. With the Cancel button still held down, also simultaneously hold down the Rotate Toner button for 10 seconds or longer.
3. When all LED indicators are blinking rapidly, release both the Cancel and Rotate Toner buttons.
4. Then hold down the Rotate Toner button again for another 10 seconds or longer.
5. The Cyan toner cartridge moves into the proper position, so it can be removed.
6. Remove and/or replace the Toner Cartridge if necessary.
7. Open and close the covers. Each time you do this, another toner cartridge moves into the proper position, so it can be removed and/or replaced (in this order: cyan, black, yellow, magenta).
The link is located here
