Purchased a set of new batteries, after charging 24 hours, still says low charge with a yellow light. anyone have this problem? wondering if it is a bad charger, or possibly throttle connection??? anyone?
SOURCE: batteries won't hold a charge
Are the batteries really gettin a full charge or is your charger faulty. If you can borrow a voltage meter you can see what your battery is putting out and check the charger (plugged in) to test how much voltage it is putting out. If the Razor is 12 volt you can hook up a car/motorcycle charger to pump up those batteries. I don't think your batts are not holding a charge, i think they're not gettin a charge....good luck to you...Tim
SOURCE: charger remains on charged status. will not switch
bang the battery until you get it pregnant ... then wait until a new battery comes out of da dirtbike's *****
SOURCE: Mx500 Razor Dirtbike battery issue
you could try charging it if this dont work you will have to replace it
SOURCE: Razor MX 650 wont run
i had the same problem but fixed it this morning, i just sat far back on the seat when turning throtle with all my weight and then slid back on normal when moving, but it makes a grinding noise.
