Joy stick goes off when you barely touch it to move scooter.
SOURCE: Just bought sed Jazzy Select for my wife. Chair
Yep you have a weak or bad battery. Even tho the chair looks new if they didn't take care of the batteries ie: charge regularly then the batteries went bad just sitting. I would check in your area for a battery warehouse or store that can get you 2 new batteries at a reasonable price. If there is an Interstate battery distributor or store near you the get your batteries there. Your Select uses 2 U1 batteries. Check out my tips on charging your batteries once you have the new ones put in. Hope this helps
SOURCE: lights scroll from lt to rt ant lights around joy
The lights indicate you are in charge mode or inhibit. Check to make sure the charger isn't plugged in. If it isn't then the inhibit function of the chair is bad and will have to be repaired Hope this helped
