Samsung RV511A01 Notebook Logo
A
Anonymous Posted on Sep 15, 2014
HOW DO I RESET MY SAMSUNG RV511 LAPTOP TO FACTORY SETTINGS
I WANT TO RESET MY LAPTOP TO FACTORY SETTINGS. AS IT IS GIVING ME TOO MANY PROBLEMS
Sonya Conlin
Level 1:
New Friend:
Problem Solver:
  • Contributor 14 Answers
  • Posted on Oct 04, 2014
Sonya Conlin
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
14
Questions
0
Helped
3168
Points
23
Turn the machine off then back on as soon as you turn it on again press the f4 follow the insructions.
Dont forget to save any files or photos etcHope this helps because they will be gone after a reset. Make sure that you have all the drivers you need.
Will i lose my emails if i reset myRV511 To factory settings
That depends. If you are using a web-based email service like Yahoo! or Google Gmail where you access your emails from your web browser, then the answer is no, anything on the website will still be there when you return there to sign on again. However, if you use Outlook to download you emails to your PC and then delete them from the webserver, you WILL lose them if you reset. Also, anything that you copied down from the server to the PC and stored will be lost. Remember, if it is inside the box (PC), color it gone. If it is in the cloud (on the web), it's OK.
1helpful
When i plug charger samsung rv511 laptop its showing plugged in not charging .how to fix to fully charge
maybe the battery is full charged. run without plugging in that is best. pluging in and battery at full charge is not a good thing.
Samsung rv511 a03za
Download the guides from the link below to assist.
http://www.samsung.com/uk/support/model/NP-RV511-A07UK-downloads
You can also run the crucial memory check to determine what you need.
Samsung rv511 webcam driver
Hi nickersgasco
Go to the following webpage to download your drivers from your webcam
Bud
http://www.samsung.com/us/support/owners/product/NP-RV511-A01US#
Samsung laptop RV511 BSOD
The BSOD is usually a sign that there is either a driver or hardware problem. If you have added anything since you got the laptop you should remove it. You should also try and run the system in "Safe Mode" (press F8 at startup). This causes the system to run without the specific drivers, and uses generic drivers.
My Samsung RV511 Laptop isn't getting power.
Most likely problem in this instance is a loose dc socket. it is a cheap fix or you can re-solder it yourself, if you have the ability.
1helpful
Touchpad screen scroll not working
You'll probably have to go to Samsung's website and download the proper drivers for it.
Trying to plug my Samsung RV511 laptop into my Apex TV via
Make sure the TV is set to VGA and not HDMI input or something else. Should be straight forward.
Top Samsung Computers & Internet Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Jean Thiebaux
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
