LG 37LE5300 LED TV Logo
A
Anonymous Posted on Sep 15, 2014
On switch does not work always
The switch does not become blue by the start up
Andy Fraser
Level 2:
Passionate:
Visited the website for 10 consecutive days.
Habit-Forming:
  • Expert 141 Answers
  • Posted on Sep 29, 2014
Andy Fraser
Expert
Level 2:
Passionate:
Habit-Forming:
Answers
141
Questions
Helped
45601
Points
202
Check your remote by pointing it at a digital camera while pressing the On button. The camera will see the Infra Red from the remote.
1helpful
Buell blast doesn't always start after running
Yes, it sounds like there is a lose wire or connection. If you can get to these wires and connections, check them for bad connections, loose connections, etc on the switches. Sometimes the contacts on the switches where the wires attach become corroded, or the terminals on the wires become corroded or loosen up, making poor contact.
I have a 523i bmw and out of the blue the windscreen wipers stopped working. It is intermittent and they stop and start when they want to which makes driving in adverse weather quite difficult. Had a...
2things it could be,the wiper motor,or the switch that turns them on,if power is going to switch and it doesn't work,then maybe switch,apply .You can always take switch or motor back if they there not the problem.
HP G61 511WM
When you wake the computer up from sleep, eventually some of the windows files become corrupted. I recommend that a proper shut down be done when not in use. Now to try and address your problem, do a system restore and take it back in time before this started, if successful should resolve your issues.
Will not turn on. have unplugged, plugged back into electrical outlet, changed outlets, etc. light blinks and becomes solid as always, but will not turn blue with switch although iPod is playing.
could be the arm or the interface or believe it or not the power supply, b and w should upgrafe the power board then look at any other issues you may have. contact their service, should be foc.
2helpful
I know the problem to my mower which is the switch seat, just a terrible design and is broke. Want to know how to by pass the seat switch. My mower is 917.274822 18.5 Ho 42"
Well there are two wires going to it. It is either normally open and when you sit it becomes closed; or it it normally closed and when you sit it becomes an open. So if you are absolutely sure it is that switch, you can remove it causing it to become always open; or you can cut off the wires to the switch, twist the stripped ends of the wires together making it always closed. There are lots of complaints on here about this same problem with this same mower and most of them work back to a broken relay which is connected to all the safety switches.
Out of the blue it overheated. then was ok for 6
Could be the radiator fans, or it could just be the belt that drives your water pump. Does the engine make a screeching/screaming sound when you start it, or at red lights? If so, that sound is a belt slipping. You might need to adjust the tension, or replace the belt if the surface has become glazed over.
No Picture
check the blue disc capacitors around horizontal output for a burn mark.
Blue screen
there's a little button under the screen that turns the screen off when you shut the top look close and flip it till it comes on, they become stiff in some models and don't always pop up so with a little flip it should
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
