I am using nokia 900 lumia windows phone, I would like to listen music from my phone via parrot. Is it possible?
SOURCE: Nokia 5800 restarts automatically
try factory reset
go to menu>applications>file manager>backup>options>backup now
this step is intended for content backup, if you don't care to lose your personal info skip it
backup done?
1.first way to apply factory settings: go to menu>settings>phone>phone mgmt.>factory settings>yes
2.another way to apply factory settings:(three finger salute)
now switch off your 5800
while it's off press and hold these three buttons at the same time send(green button) + end(the red button) + camera button(found on the side)
while you're pressing these 3 buttons switch on your phone and hold on to the 3 keys until the hands video is infront of you
the phone then asks for date and so...
tell me if the problem persists and try to clarify it further ahead
i own a 5800 and may be i can be of help
SOURCE: can i play my music on my cell phone and use the
not with a 3200ls but you can with any of the new MKi range of parrot kits.
SOURCE: nokia 6220 wont pair with parrot vm3.18????
I have the same phone and car kit.
Try sending an MP3 to the Parrot kit. I couldn't even get the Parrot BT in my car to ask for the BT password numbers but found out to try sending an MP3, which will fail by the way, and it asked for the password finally.
There was an error in my case, but then the phone asked to connect to the Parrot again and the pairing worked.
There is an issue with newer Nokia phones, something I will be thinking about next phone upgrade.
SOURCE: connecting my new phone nokia n96.to parrot ck3000.
password finally.
There
next phone upgrade.
SOURCE: does nokia lumia 900 have wifi sharing?
Yes, Lumia can be used as a WiFi Hotspot for up to 5 WiFi-enabled devices.
