Watch sat dead for several months; replaced with CR 2025 lithium batter.
SOURCE: I have a Timex Ironman Triathlon Speed + Distance...
The Timex Ironman manual and website says to take the watch to a repair facility. Nope! Do it yourself!
How to replace the battery in a Timex Ironman watch:
This is easier if you remove one of the rubbery wrist bands.
1. Take note of the position of the metal back cover. You'll need to reinstall it exactly as you see it in order to hear the alarm.
2. Remove the four screws that hold the metal back cover, and pry off the cover.
3. There is a round metal clip that holds the battery in place, covered with a transparent plastic cover which likely says, "Unlatch to remove battery". Within the center of each clip, there's a small opening just large enough for a straight pin to be inserted. A jewelers screwdrive won't work - use a straight pin. Insert a straight pin into the tiny opening at the edge of the clip, and wiggle it. The clip should release. You'll only need to unlatch one side of the battery retaining ring.
4. Gently pry up the batter retaining clip, then pry up the battery. Insert new battery.
5. Replace the clip.
6. Insert a flat blade screwdriver into a slot which has two "electrodes" or pins - they need to be shorted with the screwdriver to reset the watch. Just touch the screwdriver blade across the two pins to short it.
7. Reinstall the back cover but be sure to position the cover so the alarm sounding place ( a small disc attached to the inside back cover) will reside over the sounding spring.
8. Insert screws.
Dave
SOURCE: Set time on tghk watch
As there are no possible watch manuals for unknown brands, all I can say is:Click on my profile (escapement), then click on Tips and Tricks. There you will find links to all watch manuals.Go through all and you will find the right one, as all watches stand on globally accepted basics. It may take some time, but at the very end you will get what you want.Rate me, please
SOURCE: My TGHK watch is stuck in ''Military Time''...
advance the hours. The first time you go through the 24 hour cycle, it will be in am pm mode, the second time in 24 hour mode, the next time in am pm. Just keep advancing the hours until it comes up the correct time
This one is quite simple. Just remove the watch back with a watch case knife and flick out the old cell then carefully press in the new one (VERY carefully as the movement is made of plastic). fit the back exactly the way it came off (note the direction of the writing).
