How do I fit the belt on the mower deck
The best way is to remove the deck from the mower. At this time you should grease the pulleys and spindles. there are four post that hold it. two on either side and one in the front. they are held by cotter pins. lower your deck level down makes it easier. you will have one engagement cable that just pops out it has a spring on it. then slide it out from the easiest side or pick the mower up and pull deck out . at this point it will be apparent where the belt goes and do your your other maintenance of cleaning and lube. factory says lube spindles every 8 hours of use.Then put it back under and re attach.
