Question about Sony VPL-EX5 Projector
How to removed Lamp/cover error of Sony VPL-EX5 projector?
My projector is not working there lamp/cover signal indicator blink but projector not run.
  • 985 Answers
Take the lamp cover back off. Check the mechanism that the projector uses to sense the door. It might be a small pressure switch. Check whatever triggers the mechanisms is still attached to the door and hasn't broken off.
Posted on Sep 16, 2014
3 Suggested Answers
SOURCE:
welcomejee
  • 10594 Answers
SOURCE: how to reset lamp on sony lcd projector xga vpl-px20
After replacing lamp, connect projector AC power cord and turn the projector in standby mode.
Press following keys on control panel for less then 5 seconds each..
RESET, <==, ==>, ENTER.
That will reset lamp timer in projector.
Thanks.
Posted on Jun 01, 2009
  • 5 Answers
SOURCE: When the SONY VPL - ES1 projector is turned, the
definately a lamp problem, for some reason the projector doesnt seem to accept or recognize the new lamp and switches to "safe mode". usually the projector turns off before the bulb explodes...
Posted on Aug 04, 2009
Green light is continuesly bling but the projector is not given the display
1,Check the fans ,whether each fan is running,when you turn on the projector
2,if the fans run, then ,check the lamp or lamp ballast
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Dec 11, 2014 | Sony VPL-BW5, VPL-ES5, VPL-EW5, VPL-EX5,...
Sony ex5 rgb not working
replace the LCD panels (USD220)
Have a good day!
Jerry Lampdeng Limited
Mobile: 0086-13178867858
Wechat ID: 008613178867858
Whatapp ID: 008613178867858
Skype: lampdeng@hotmail.com
http://www.lampdeng.com
Feb 25, 2014 | Sony VPL-EX5 Projector
Sony projector vpl ex5 yellow display problem
try replacing the bul/lamp.
warning! $200 part http://www.amazon.com/Projector-LMP-E190-VPL-ES5-VPL-EX5-VPL-EX50/dp/B003ISW2KM
May 21, 2011 | Sony VPL-EX5 Projector
I have changed the lamp in a Sony VPL EX-1. I have fitted a YODN (LMP - C150) I cannot get the flashing light to go out which indicates `lamp,cover` and I cannot do anything with the projector.
When you open the lamp cover for replacement of lamp there is a switch in the projector is OFF
If lamp cover not fix proper after replacement of lamp the lamp/cover indicator flashing
SOLUTION: Open the lamp cover and fix proper and tight the screw
Feb 22, 2011 | Sony VPL-EX1 Multimedia Projector
Lamp/cover lite is blinking and projector can't start
Remove the lamp and reseat it carefully, following the instructions in the user manual.
If this doesn't help you may find that you need a new lamp.. if you are in the UK you can purchase a Sony VPL-EX5 Lamp here or from here if you are in the USA
Feb 14, 2011 | Sony VPL-EX5 Projector
Sony VPL-CX61 lamp/cover blink. Power on, it
hi,
your projectors lamp cover may be open. or there is some thing happened (may be contact problem) with the lamp cover open sensing switch. just open the door and close it. and then try again.
ok
Dec 20, 2010 | Sony VPL-CX61 LCD Projector
Can't on
The service manual states that a blinking lamp indicator means the lamp cover is not attached securely or the air filter is not inserted properly. You may try removing both and re-attaching to see if this clears up the problem.
Jul 19, 2008 | Sony VPL FX50 Multimedia Projector
SONY VPL-CS3
Hi there
Replacing the lamp won't make any difference at all.
If you have checked the fuse on the Powersupply Board and it tested ok , then the whole Board will need replacement.
Apr 29, 2008 | Sony LMP-C121 Projector Lamp for VPL-CS3,...
Lamp/Cover Error
I had the same problem with a "Sony VPL-ES3" projector. The lamp cover light would flash and the projector wouldn't turn on.
I think its a problem with a filter cover. This fixed the problem for me:
  1. Plug out the projector
  2. Click off the filter at the bottom of the projector.
  3. Plug the projector back in. (the lamp cover light should flash)
  4. Plug the projector out again.
  5. Put the filter cover back on.
  6. Plug the projector in again and it should work fine.
This has worked for me every time I have had this problem.
Sep 29, 2007 | Sony VPL-ES3 Multimedia Projector
Sony VPL-EX5 Projector Logo
1,429 people viewed this question
Top Sony Office Equipment & Supplies Experts
Jaime Hernandez
jasbo
jasbo
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
