50hp evinrude lark has spark but will not start can u tell me y please
SOURCE: I can't lower the motor into the water
I the metal rod to pull out on the starboard side.
Thanks
SOURCE: starter motor wont work evinrude 50hp 2cyl
Sometimes there is a switch which prevents the starter from working in gear. This switch could be out of adjustment. Otherwise you need to check for a bad relay by jumping the one you can find and seeing if the starter will turn. Check the grounding on the motor too.
