The sat light will not come on and will not operate the tv
The System Wizard button helps the remote store its settings inside the receiver as a backup, and then also backs up the receiver settings inside the remote, in case either needs to be replaced. It works best when you start the wizard while the remote is set down on a table or sturdy surface close to the receiver. If the remote won't leave the wizard, make sure you've exited all on screen menus (use the keys on the receiver) then remove the batteries. Replace the batteries after a short wait, but don't wait more than 5 minutes. After doing this, hit Sat, and the remote should restart.
SOURCE: Echostar IR remote (Dish)
to set remote to tv
1)hold down tv button next to sat button in top left corner
2) when all buttons illuminate press 500 into remote
3)press pound sign
4)Hello, please help..
5)hold town tv button again.
6)when all buttons illuminate press big red power button
7)press up arrow once a second until tv shuts off
8)press # pound sign
9)try to turn tv back on w/ big red power button
10)if tv doesnt turn back on try again from step 2 but use down arrow instead
to set remote to receiver you need to access system info, if there is no sys info button on your receiver turn power off and press the up arrow, then press record 2 times on the remote,
SOURCE: dish hd dvr remote won't work. brand new. it
It sounds like you have interference, try removing the uhf ant from the back of rec and promgram it straight from there. you can also hookup "bunny ears or a pigtail coax to the uhf ant port to increse uhf signal. also make sure the uhf ant is standing straight up.
SOURCE: i have reprogrammed my dish remote to my tv but
Press menu -menu on the receiver. You should be able to see the remote address for the receiver. It will typically be set to 1 if it reset somehow but whatever the case make note of this number. Take the remote and hold the SAT button until all lights across the top illuminate. Now key in the two digit address- single digit numbers are preceded by a 0. Now press the pound sign in the lower right of the remote and observe that the SAT button flashes thrice. Now press the record button a few time to ensure it is locked. Now try exiting the menu screen with the remote.
If this does not work check the antenna on the back of the receiver and put it in the full vertical position and try again. If this fails you may need a new remote.
Thanks for using for using Fix Ya.
Ihope this resolves your issue.
SOURCE: Remote to TV 1 doesn't work - buttons light up, nothing happens
Press the number zero for 10 seconds and wait until the "remote wizard" pops up. Then just follow the instructions on how to program your remote to your receiver box.
SOURCE: Dish Network IR Remote's SAT Mode Not Working ____
Hello, this is Nick Franta with DISH.
If you are trying to get the remote programmed to the receiver you can remove the smartcard from the receiver and that will prompt the system info screen. This will allow you to program the remote to the receiver.
If you need the process for programming the remote, here it is:
Hope this helps!
