Frozen won't reset. appears locked. no password was installed when received from an elementary school giving them away to students who attended afternoon program. Does charge battery but won't do anything else. None of the buttons on it work. can I return it to manufacturer? only used a couple of weeks. school won't replace it or send for repairs. MID7034-4; Android 4.0;
SOURCE: my android tablet is "frozen". Will turn on but
has anything been deleted from it when it has been plugged into a computer or has anything been deleted from the device itself from its root directory? if not and its gone like that by itself, it could be corrupted software or a missing root file which is usually bad at first, now what i know about some tablets is if it wont work theres a recovery file usually internally but this is in some tablets only that ive read about, i also have one but havent needed to try to restore it and it can be done from an engineering mode, this is possable by pressing the power button and another button like the home button at the same time once the unit is off untill it turns back on with options, but as for some models im not sure of but i will have to look this up at some stage as i am working on tablets at this time so unless you know what you are doing i wouldnt attempt it, once i have gotten through some tablets ill be able to give a better resolution on this subject with others. the advice ive given wont work for all as pressing power and home will start different options up on different tablets and versions.
try to hard reset or soft reset, for this procedure search on gogle.com how to reset tablet, that will be helpful.
SOURCE: tablet crashed won't do anything
plug it in for 5min.then hold the power button for about a min. I hope it works it did for mine.
TRY a hard reset on the Nook if that doesn't work i know of this fantastic site BNTPrice.com that sells them for cheap. i hope this works for you
Press the "n" button to display the quick nav bar.
In the quick nav bar, tap the Settings icon.
In the Device Settings section, tap Device Info.
Tap Erase & Deregister Device.
Stop. Think. Think again.
If you really, really want to do this, go to Step 7. If not, tap the Back button.
Tap the Erase & Deregister Device button.
