Cannot get ipad 2 to shut down by holdildg power and home buttons
Press and hold the Sleep/Wake button on the top of your device until the red slider appears. Then drag the slider to turn your device completely off.
After the device turns off, press and hold the Sleep/Wake button again until you see the Apple logo.
You should reset your device as a last resort and only if you can't restart it.
To reset, press and hold both the Sleep/Wake and Home buttons for at least 10 seconds, until you see the Apple logo.
SOURCE: my ipad is disabled how do i fix it
Try connecting it to iTunes, turning off the ipad, then hold both the lock and the home button for 10 seconds, then relese the lock button while continuing to hold the home button until iTunes recognizes the iPad. Then you should be able to reset it without problem.
SOURCE: IPad shuts down itself
It seems that you've already tried reset (holding the home and power buttons, right?) the iPad and it does not work.
So you may need to connect your iPad to your computer and do a factory restore using iTunes.
Check this: http://support.apple.com/kb/HT1414
SOURCE: how do I unlock a locked up ipad?
If you've got a locked up iPad app or otherwise misbehaving iPad, and
want to reboot / reset your iPad, simply hold the sleep and home
buttons together until the iPad restarts.
You'll see the shutoff slider come up first, but just keep holding.
The screen will go blank and the Apple logo will reappear as the iPad
reboots.
Note: this does not reset any data on your iPad. This is just a restart, equivalent to rebooting your computer.
It may be a hardware fault, what I would do is given that it is a new ipad take it to the local Apple Store and they will either replace it and have it repaired.
