Cleaned the ice maker yesterday. was making ice. This morning no ice in bin big glob of ice on ice plate
SOURCE: Water leaks into storage bin
open the machine control panel side and cube adjustable thermostat available in side,adjusted in the thermostat screw
SOURCE: B198 ice maker
try the water inlet valve it may be stuck open or check to ensure your water preshure is no higher then 65 lbs.
SOURCE: My clr 2060 ice maker is not doing anything,their
HI
It sounds like you have a drain issue. You can do a test with the unit on open the panel with the board and remove the 2 pink leads and make a jumper for those terminals. If the unit comes on 3 min fill then circulating pump and compressor and fan come on then you know you either have a kink in the drain line or a bad pump. If your unit doesnt have a drain pump then the pink lines could be open and it will turn the unit off too.
SOURCE: Melded mass of ice in bin
your unit could be cascading water into bin..make sure baffle in the back is on..if you put your hand in bin where ice falls..youll feel a considerate amount of water falling...make sure your keeping door closed...just turn off..bout half way full..see if it makes a difference
