Patton PQH307UM Electric Utility Heater Logo
A
Anonymous Posted on Sep 14, 2014
Change out a switch for a patton heater 1 2
Only one coil is heating up. the problem seems to be in the switch
3 Related Answers
A
Anonymous
  • Posted on Jun 09, 2008
SOURCE: Patton ceiling heater Model# 2433
x48987
Anonymous
  • 9 Answers
  • Posted on Jan 20, 2009
SOURCE: I have a small space
Not worth fixing. Take $20 and buy a new one.
Anonymous
  • 43501 Answers
  • Posted on Jan 16, 2011
SOURCE: my Patton PUH680 space heater is not working. Do
Check out this tip that I wrote about space heater problems..
DeLonghi Space Heater does not Heat
heatman101
Can I buy a heating element for this heater?
On google
Patton replace heating element Heaters Questions ... - Fixya
www.fixya.com > Forum > Tags > replace heating element > Heaters
Patton heaters replace heating element related questions and answers. Ask yourPatton ... I can't seem to find a phone number for the manufacturer to call for parts. Any help? ... Question about PQH307UM Electric Utility Heater. 1 Answer ...
Patton PQH307UM Electric Utility Heater Quartz elements ...
www.fixya.com > ... > Patton > Patton PQH307UM Electric Utility Heater
Patton PQH307UM Electric Utility Heater, quartz elements replacement related ...Element. Where can I find replacement quartz tube heating. Element Infrared ...
Patton PQH307UM Electric Utility Heater Element ... - Fixya
Patton PQH307UM Electric Utility Heater, element related issues. Get free help, solutions & advice from top Patton experts. ... The heating element is above the thermostat, and all you will see is a round disc with two wires attaching to. Ad.
Patton PUH680-U Utility Heater Replacement fan motor ...
2answers
Starts then shuts off
My Mighty Heater 1500 will run for 15sec then shuts off then repeats it over an over
1helpful
2answers
I purchased the Patton PUH9000 heater last year. I puts out a lot of heat at first, but shuts itself off after about 5 minutes, then cycles back on after a couple of minutes. Is this normal operation? I...
My Patton PUH682 utility heater from 2011 is otherwise in excellent condition but Auto Safety Shut-Off seems to be a design problem. My overheat sensor quickly shut off the unit when surrounding air was cool. It is inside the bottom of the fan box wired between the on/off potentiometer and heating coils.
I identified it by turning on the heater and watched the metal contacts separate as it tripped. On my unit, the defective overheat sensor is hardwired. Since it was otherwise useless as a heater, I decided to jerry-rig it and hope for the best. I pried back the sheet metal edge of the fan box and wrapped the sensor with electrical tape. Then I took a very small squeezable metal paper clip and lined it with electrical tape. I clamped it over the overheat sensor and it fits perfectly to prevent the metal plates from separating. Now the heater works the way it should. The cable, coils and plug don't overheat on Hot setting and it runs continuously.
My Patton PUH680 space heater is not working. Do you offer replacement coils?
heatman101
2answers
I have a patton puh682 1500 watt heater and after a while it just seems to turn off is there some kind of timer or heat control?
Under the main black knob is a bi-metal switch which shuts down the heat at various temps depending on your setting. Their is no timer.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
3helpful
4answers
When the alarm on the Patton Electric Heater sounds, whay does one do to fix that?
This heater was the determined cause of my total loss house fire. I thought the company would atleast help me find some where else to live, they seem to care. But, as of lately they are doing nothing.
I am told this heater-(prh11- 2008 model- purchased at walmart for about $27.00)
- Had wiring that wasn't up to standards
-1/10,000 units cause fires
-something wrong with the heating element-stops working
- wouldn't stand level
-heating coils
-fires like mine have happened to a few other people
This came directly from a person at Jarden corporation(aka patton-sunbeam)
2answers
Coils not all working
the heating coil may be broken and shorting out to the case. it is a nichrome resistance wire. replace it.
Top Patton Heating & Cooling Experts
Jay Finke
Jay Finke
ADMIN Andrew
ADMIN Andrew
Paul Carew
Are you a Patton Heating and Cooling Expert? Answer questions, earn points and help others
