I changed the battery and set the time OK but the chime did not work. Does it need setting? I have no manual for the clock
Seems like they have gone bust friend !
Cant find w993 manual.
Some instructions I found.
http://grandfatherclocks123.com/haller_w97_Movement_instructions.html
http://billsclockworks.com/merchandise/instruction-sheet.html/3
Testimonial: "thanks for the answer mate. I still could not figure it out :D."
SOURCE: Set the clock to DST
Try this link and follow the instructions.
http://www.lacrossetechnology.com/3143a/manual.pdf
SOURCE: my solar clock needs setting. I set it back an
1) Pull the batteries and replace them, or gently insert a straightened
paper clip into the "reset" hole in the back of the clock. The clock
will beep.
2) Press the "receive" button" so the clock sets itself. The default time zone will be "EA".
3) Press the "adjust" button untill the time zone is showing (rather than the day-of-the-week).
4) Press and HOLD the "set" button down untill the hours digits start to flash.
5) Now press the "set" button again six times. The time zone characters will flash.
6) Press the "adjust" button untill your time zone appears.
7) Press the "mode" button to return the clock to normal operation.
8) Press the "adjust" button to display the day-of-week.
SOURCE: I NEED THE INSTRUCTIONS FOR SETTING THE CHIMES/TIME ON MY WESTMIN
Manually turn the minute hand forward until the 16 westminster chimes sound and then the hour strikes. Then remove the minute hand (it will go on in four positions) and put it back on at the 12 o'clock position. The chimes should now be back into sync.
Fred
SOURCE: Mantel Clock With Westminster/Whittington Chime: How to set the chime properly...
Pressing the red button advances the chime count by one. Continue to advanced the chime count until it matched the hour shown on the clock face.
