I have 6 wires - braided, white, yellow, red, blue, & black. Need to know color code for 4-pin connector on Cobra M75 CB Mic. The diagram I have shows Pin 1-Shield: Ground, Pin 2-White: Audio Out, Pin 3-Red: Transmit, Pin 4-Black: Receive. I don't think I put enough info when I ask before.
it doesn't make a difference what color wire it is as long as the wire is connected to the function it is going to control If your mic has a red , blue , black , and shield wires but your radio isn't set that way you have to set it to the way your radio is . you have to find out where ground is then audio in and audio out then the last is the shield.
Here are the Pin outs for different mics that will work with your radio. If a wire is not listed then you cut it off. It's best to keep the wires as short as possible no longer than a half inch is suggested. Normally the Cobra pin out is standard for most radios.
Stock - 1- Shield (Ground) 2- Yellow (Audio) 3- Red (Transmit) 4- White (Receive)
Astatic - (4 wire) 1- Shield 2- White 3- Red 4- Black
Astatic - (6 wire) 1- Shield & Blue 2- White 3- Red 4- Black Yellow NC
Daiwa EM-500, Cobra, CA Series - 1- Shield & Black 2- Red 3- White 4- Blue
Galaxy DC-521S - (4 wire) 1- Shield 2- Yellow 3- Red 4- Black
Galaxy CB-660EI - 1- Shield & Black 2- White 3- Red 4- Blue
Sadelta - 1- Shield 2- White 3- Brown 4- Green
Turner - 1- Shield & Red 2- White 3- Blue 4- Black Yellow NC
Here is the wire diagram for several common mics in relation to a 4 pin CB. Most recent 4 pin CB's such as Midland, Cobra, Connex, Uniden, etc can use 4 pin mics. The wiring is actually depending on the mic rather than the CB so long as the CB's are 4 pin as well. Once you go back to late 80's the 4 pin design was a little different. Anything new it is simpler.
Stock Mic
1- Shield (Ground)
2- Yellow (Audio)
3- Red (Transmit)
4- White (Receive)
Astatic - 4 wire
1- Shield
2- White
3- Red
4- Black
static - 6 wire
1- Shield & Blue
2- White
3- Red
4- Black
Yellow NC
Daiwa EM-500
Cobra CA Series
1- Shield & Black
2- Red
3- White
4- Blue
Galaxy DC-521S - 4 wire
1- Shield
2- Yellow
3- Red
4- Black
Galaxy CB-660EI
1- Shield & Black
2- White
3- Red
4- Blue
Sadelta
1- Shield
2- White
3- Brown
4- Green
Turner RK56 Road King
1- Shield & Red
2- White
3- Blue
4- Black
Yellow NC
Regards,
Tony
Mic Wiring Stock
1- Shield
2- Audio
3- Transmit
4- Receive Astatic (4
wire)
1- Shield
2- White
3- Red
4- Black
Astatic (6
wire)
1- Shield & Blue
2- White
3- Red
4- Black
Yellow NC Daiwa EM-500
Cobra CA Series
1- Shield & Black
2- Red
3- White
4- Blue Galaxy DC-521S
(4 wire)
1- Shield
2- Yellow
3- Red
4- Black Galaxy CB-660EI
1- Shield & Black
2- White
3- Red
4- Blue Sadelta
1- Shield
2- White
3- Brown
4- Green Turner
1- Shield & Red
2- White
3- Blue
4- Black
Yellow NC
1) violet 2) blue 3 ) shield 4) yellow 5) grnd Violet inside the mic is the power wire . Blue and yellow are the internal and external speakers. the other wires are to the antenna
