LCD Display +Touch Screen
Digitizer for LG KP500 KP501 Cookie ~ Repair Parts Replacementby BuythestuffPermalink:http://amzn.com/B003GX7W2W
THIS WILL FIX YOUR PROBS ONLY $26 !
You should run touchpad calibration. It's in Settings->Touch Settings->Touchpad calibration. While doing the calibration you should accurately tap at the center of the black cross with a stylus.
Hope this helps.
You can buy a replacement touchpad at flexqueen.com for not that much money. The installation is not that difficult for that model You can try youtube for a video on the installation.
Hi Acostawifee0 it sounds like you have a software crash on the phone. Try taking out the battery. They may not be much you can do if the battery pull doesn't work. You may need to call lg or the carrier to get a replacement phone. uNLESS THE CARRIER HAS A SOFTWARE DOWN FOR YOUR PHONE. One of your best answers id to go to lg's website and find out what is there solution for the problem.
Gently bend it like you're trying to split it with screen facing upwards or squeeze around the camera. Amusing solution but it works. recalibrate your touch settings afterwards (menu>settings>touch settings) for perfect operation
For unresponsive touch screen, the common cause of the problem is a damaged digitizer.
Since the LG KP500 does not have a keypad that you could use, you need to replace entire LCD assembly unless you can get a split LCD/digitizer assembly.
If you're not sure how to replace it, you can either send the phone to the manufacturer or take it to a local cell phone repair shop.
