One burner quit working some time ago now code F7 flashes all the time, this happen while the oven was in use.
Hello Friend, thank you for allowing me to assist you!
If you are receiving an error code F7, it usually indicates that one of the surface burner switches has failed. This is not a typical DIY job. Before reaching out to a professional, let's attempt resetting your Frigidaire range. You can do this by unplugging it or flipping your circuit breaker into the off position. If the error persists, in that case, a certified technician would generally replace the faulty part after proper diagnosis. Hope this helps! - Z
SOURCE: oven will not work
First look to see if the ignitor is coming on. Most common problem is the ignitor is weak or just bad. When the power is applied to the ignitor it glows and builds up resistance to open the gas valve then it lights. If the ignitor is weak or bad it will not build up enough resistance for gas to come into the burner. One sign of this would be a "woosh" sound when it trys to light. If the ignitor is coming on but not lighting it is most likely the ignitor is bad. Should have a full glow. Also, if the ignitor looks whiteish in color this is a sign of it going bad. You can compare to the broil ignitor to be sure. Let me know what you find and let's solve it before you rate the solution.
SOURCE: whirlpool sf325peg oven not working
SOURCE: GE OVEN HAS QUIT WORKING...F7
Hi Rayham,
Happy to help you!
THIS IS AN OLD MODEL AND I WOULD NOT SPEND ALOT OF MONEY FIXING IT!
TRY THESE GUYS
Go online to www.Frigidaire .com and you can enter your model # and download the manual.
if you can not locate the answer in the book,
I think that this problem will be solved only by service!
A & E factory service is good and nation wide!
1-800-905-9505
They answer 24/7
Thank you Neil
PS.Please do not forget to give me a problem solved rating
SOURCE: while using kenmore 790.9621 smooth
It appears your Ignitor has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Testimonial: "Thanks for your answer. I've been upside down with this thing! I put a new 4 prong 40amp cord on it and it looks like it solved the problem. Thanks "
