Cars & Trucks Logo
Posted on Jul 03, 2009
Front windscreen wiper wont stop why its a mitsubishi lancer evo4 i was touching the windscreen washer pump which had ceased working wipers came on and wont stop have to take the fuse out to stop them
Anonymous
Level 1:
Problem Solver:
  • Contributor 19 Answers
  • Posted on Jul 03, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
19
Questions
0
Helped
8229
Points
45
Most cars turn on the wipers when the washer pump is turned on. Look for a stuck switch or relay in the washer circuit. It seems that the wipers think that the washer is on.
3answers
Front windscreen wipers stopped working
turn the wipers on fully and try tapping on the wiper motor, sometimes the brushes freeze...
1helpful
2answers
Windscreen washers stopped working. all fuses ok,wipers working ok.front & back washers not working
Hi, First check that you have wash liquid in tank. second make sure that it will not freeze by putting alcohol in your mix of water and soap. You can buy it already mixed at most service stations. Check pump for corosion on contacts.
Good luck.
2005 audi s4 - windshield wipers stopped working / ceased up. Will go up approx half way, then EXTREMELY slowly continue up then down (approx 20 mins for one cycle). Is this the linkage or another issue?
First time you must diagnose why windscreen wipers going slow and/or stopping.
In order to find out the cause of wipers stopping you can try follows:
1. Carefully extract the wiper arms from their axles (two pieces). In some cases you need to use an extracting tool. Heed of the windscreen !!!
2. Disassemble the plastic covers from the bottom of the windscreen.
3. With the bonnet up you can start the engine, (transmission in "N" or "P" position and parking brake on). Now you must switch on the control lever of the wipers, and go to the engine compartment. If the wiper motor runs let the wiper motor running for a few minutes and switch off. Go to the step 4. If the wiper motor do not runs you must check first the electrical feeding of the motor. It is necessary to unscrew three bolts of the mechanism and disconnect the electrical coupling (difficult assurance). If the electrical feeding is OK you must replace the motor - steps 5, 6, 7. If not you must check electrical connections, the control switch of wipers and electric cables.
4. Now you must check the two bearings of wiper mechanism with your hand. In the most cases the left bearing is out of order (is very hot). This is the most encounter fault of the wipers running at Audi.
5. For have enough space to manipulation the wiper motor together with their mechanism you must extract the plastic cover of the engine computer box, and extract also the box screws. Then you can move slowly the engine computer box, just for a few milimeters.
6. You must disconnect the electrical coupling of the motor (difficult assurance), unscrew three bolts of the mechanism and extract together with the motor. You must move them slowly between windscreen and engine computer box until the wiper motor go out together with the mechanism. This is the most difficult operation!
7. Now you can repair the bearings, replace entire wiper mechanism or replace the wiper motor. It is not very simply, but it works.
Refit all in reverse order.
4helpful
2answers
Wipers worked one turn then stopped
may have broken bushing in one of the arms in the wiper linkage, remove the cowl and take a look. most part stores sell replacement bushings start there good luck.
I need windscreen wiper switch column mounted for 1998 mitsubishi lancer wagon. Low and high speed work but not intermittant
I had the same problem in my Saab. Replace the column with the buttons and you should be good to go. Check with eBay and local junk yards for the part.
2helpful
3answers
Windscreen wiper wont turn off
pull the fuse if it wont stop, faulty switch or relay sticking. get it from the junk yard. more likely it the wiper switch is faulty.
The windscreen wipers seem to have been disconnected from the motor on my 2006 lancer after the car wash knocked them.
check the end of the wiper. Under the cover at the end of the wiper there is a 10mm nut. it comes loose sometimes.
Windscreen Washer
If it is the same as some other Chevrolets they have 2 pumps attached to the side of the washer bottle. 1 for rear and 1 for front windscreen
Windscreen wiper not working
check the switch on the steering usualy it becomes faulty after a while and also your window washers could be blocked but try turning it on if you do not hear a buzzing sound the motors needs to be replaced.
Top Mitsubishi Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Mitsubishi Expert? Answer questions, earn points and help others
