I have never used drainage hose, but just empty bucket when full. Frigidaire 50-pint dehumidifier is two years old. The bucket is not leaking. The leak is coming from somewhere else.
Hey friend, thanks for your post!
It sounds like your dehumidifier needs to be professionally cleaned. What could be causing the problem is a buildup on the inside of your dehumidifier where the water drains out and it is causing the water to not drain properly. Additionally, I would check to verify that the drain hole is tightly secured with the plug. I know you stated that the bucket is not leaking but have you removed it to verify? Please comment back if further assist is needed. -Matt
SOURCE: I want to have my new 50 pint Frigidaire
The reason this occurs are as follows:
1. The hose is to long (should not be more than 5' in length) or does not slope down and run directly to a floor drain.
2. The hose is clogged or the hose connection on the unit and it's internal tubing is clogged.
First turn the unit OFF & unplug it.
The hose is easy to check by disconnecting it and blowing thru it. If the hose checks out, then it's the connector and internal tubing. Because when this happens, water is diverted to the bucket.
Using an appropriately sized, 18" long, plastic
Zip Tie, carefully insert the tip of Zip Tie into the hole or tubing.
Continue to push it in until you reach a bend in the tubing. You will
need to gingerly work the Zip Tie past this bend, until it either
bottoms out or you run out of usable Zip Tie. Then slowly pull the Zip
Tie back out while rotating (twisting) it. This will breakup any clogs.
As you reach the inserted end of the Zip Tie, be prepared, as some water
may follow. Reconnect the hose, plug the unit in and turn the Master
ON/OFF Switch to ON. Set the humidity extraction level to 35% or
Maximum if you have a manually controlled unit. Allow the unit to run,
while you monitor the hose for water flow.
NOTE: If you don't have a Zip Tie, you may use something similar ( i.e.a long pipe cleaner), but NO wire coat hangers.
Hope this helped you solve the problem. Please let me know and thanks for choosing FixYa.
If you have a dehumidifier that is not producing any water
then you are wondering what you need to do to get this thing to work
for you. In some cases you may be able to do something and in other
situations there may be nothing that you can do.
If you do not hear the compressor running and the unit says that the humidity in the room is higher then the setting, then you have a problem with your dehumidifier.
A few things that can cause this are:
The circuit board relay has gone bad...replacement of this board will often cost more then a new unit. This also is a very common problem with many dehumidification units.
The compressor has failed...if
you hear a buzz for a few seconds, every few minutes, then you have a
bad compressor or at least bad start components on the compressor.
Either way it again is a costly repair.
If the compressor is running and the coils are not getting cold then you have a refrigeration system leak. Recharging or fixing these units is very difficult and is another costly venture compared to the price of a new dehumidifier.
If the compressor is running but the fan is not, this also will cause low water production and continual freezing of the coil.
If the compressor and the fan are running but the coil is totally blocked then you will get no water production. Air needs to be continually moved over the cold coil to get the water out of the air.
If nothing is running, then you may also have a control board failure. Or the humidity sensor or humidistat has gone bad which tells the machine to run. If the sensor says that the humidity is low enough then it will never run.
Also if nothing is running check the float switch or the bucket switch.
Many of these switches are very touchy and if you do not have the
bucket in place just exactly right it will not trip the switch to allow
the unit to run. These switches often are more fragile then they should
be and break easily. The good thing is that when available they are easy
to replace and relatively inexpensive.
There are some parts
available for a few brands, but with the prices for most of the parts
that you can replace running anywhere from 40.00 - 80.00 dollars,
replacement parts with labor to install them, makes a repair more then
the few hundred dollar cost of many of these dehumidifiers.
As
you can see there are quite a few things that can cause your
dehumidifier not to work. Systematically go through the list and
eliminate things to get to the bottom of the issue causing your problem
and then decide if it is worth spending the money to try to fix the old
unit. Only you can make that decision.
Description:
Pump-drain
No. in Pack:
Additional info:
Dehumidifier pump assembly conveniently attaches the pump kit to you dehumidifier. connect a run hose to a nearby sink, pump, or floor drain. this pump will push water through a hose to up to 18 vertical feet for drainage through a window.
Stock Status:
In Stock
Price:
$107.79 -
This part is also known as:
8212501
If you can gravity feed it and can get a hose around the output pipe then any flexible hose will work that is slightly larger than the output pipe.
