Question about Irons
How do I replace a cord on a rowinta iron
We have a bad cord on the rowenta electric iron. We have a bad cord
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 173 Answers
Open it and takeout the old cord you will see screws at the back ithink infront its have clips butthere is no oyher way
Posted on Sep 14, 2014
SOURCE:
SOURCE: rowenta dx6700
The wire inside the cord is likely torn ant it connects and disconnects as it is moved back and forth. This happened to me too. I just need to find where to get a new cord.
Posted on Jul 31, 2008
wizzard8955
  • 18 Answers
SOURCE: My Rowenta iron will not heat up. The yellow light
Inside the iron is a piece of thermal metal the is supposed to make contact with a small ceramic pin with a metal cap on it. I think this was intended to be a safety device but they fail and the iron will not heat up. The part does not seem to be available so easiest way to fix is to put a small bead of glue on the housing that forces this to make contact.
Posted on Mar 06, 2009
SOURCE: Rowenta Iron
Special screw called "Torx tamper proof" call 925 8271011 and order "Rowenta tool" $10.00 plus shipping-this place also sells Rowenta parts
Posted on Jul 06, 2009
  • 2976 Answers
SOURCE: Iron spits out rusty water. The iron is a Rowenta
Fill it with a mix of 50% white vinegar and 50% water. Let it set for 30 minutes and steam it out for about 2 minutes. Unplug it and dump it. After it cools colpletely, fill it with water and steam it out. The rust is coming from your water supply, not the iron.
Posted on Oct 06, 2009
SOURCE: wiring diagram for Rowenta DE-05
I took the iron apart for cleaning and installing a new cord and neglected to note which wire goes where. Does anyone have a wiring diagram for this iron?
Posted on Sep 26, 2010
Rowenta 1500w bad contacts repairable?
If the thermostate contacts are bad you can clean them with sand paper. You should test the flexibility of of them to allow the work properly under heat. If are the cord connections are bad replace the terminals with ones os the same size or replace the power cord.
Jun 18, 2012 | Rowenta Irons
I own a Rowenta Steamium DW9080 steam iron. I need a replacement plastic door for the water reservoir. The iron is functional and I do not feel it necessary to purchase the entire handle and cord...
Not familiar with that newer model, but here is the local dealer who is most helpful in California:
California Electric Service in Concord CA (it is the only Rowenta repair station in California) go to either of the following addresses:
their website is: http://www.californiaelectricservice.com/
or tech service: service@californiaelectricservice.com
Aug 29, 2011 | Rowenta DG-980 Iron
Can i put the cord of my rowenta iron together with electric tape one of my grandsons cut it
Well you could, but the real question is would you want to ESPECIALLY with loved ones about. I would say no...the long cord is easily replaced and you can get here:
Aug 22, 2011 | Rowenta DG-980 Iron
My Rowenta iron was working fine the last time I used it. I plugged it in to use it today and nothing. The little red light on top comes on but the light on the side to let me know it is ready and hot...
Yes there is a solution, I have a DG580 with the same problem. I had to replace the electric cord which cost $17.00 and took 30 min to replace and now works like brand new.
Steve
Dec 02, 2010 | Rowenta Irons
Rowenta cord repair
I would get the part for your specific Rowenta iron from the Rowenta service center for this half of the US:
Then, if you do not want to send it there, go to local Applicance servicer you trust to have cord replaced locally if you prefer. I know it seems picky, but consumer products are UL approved, and I would not want loved ones working with a product I did not have serviced properly.
May 25, 2010 | Rowenta DG-980 Iron
Iron turns off by itself while using it. I have to move the cord around in order for the iron to turn back on.
you may have a bad connection in the cord wires will need a new cord replacement or new iron
Dec 11, 2009 | Rowenta DZ5080 Iron with Auto Shut-off
My Rowenta iron will only heat when plugged into one specific outlet (other things work in the outlets that the iron "doesn't like"), and sometimes it will only heat if you giggle the cord around a bit in...
Sounds like the plug and/or the cord are bad...
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
Dec 05, 2009 | Rowenta Perfect Iron
My rowenta stopped heating , mid-shirt!!......now it seems dead and wont heat at all !.........thanks !!!
The most likely cause is a broken wire in the cord. Replacement should only be done by a qualified electrical appliance repairer. Ask for a quote as it may be cheaper to buy a new iron!
Oct 04, 2009 | Rowenta Powerglide DM273 Iron
My rowenta iron keeps shutting down while I'm ironing. What can I do ?
The cord is bad...
heatman101
Apr 25, 2009 | Rowenta Effective DX1900 Iron with Auto...
Irons Logo
117 people viewed this question
Top Irons Experts
Marvin
Marvin
Are you an Iron Expert? Answer questions, earn points and help others
