Look on the bottom of the router, it often has the IP address , username and password there. The username is usually admin, and in many cases you can't change it.
If that doesn't work, you will also find the model number there, google [model number] default password and you should find something.
final option is a hard reset! but that will wipe most of the settings and often require you to call your ISP to set it up again. Google [model number] hard reset or factory reset.
SOURCE: can't configure dir-600 after enabling access point only
Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.1.1
or
http://192.168.2.1
or
http://192.168.0.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router.
If you are still not able to access it with above ip then press RESET button for 10 seconds it is in back side of router.Then you can access it with 1 of the above ip.
Let me know if you need further assistance.
Thanks for using FixYa.
