HP Deskjet 3050A J611G Inkjet Multifunction Printer - Color - Plain Paper Print - Desktop - Gray - HEWCR232A Logo
A
Anonymous Posted on Sep 13, 2014
How do I install cartridges?
Show me details for installing the cartridges into the printer
Mark Taylor
Level 3:
  • Master 728 Answers
  • Posted on Sep 14, 2014
Mark Taylor
Master
Level 3:
Answers
728
Questions
0
Helped
335275
Points
2225
Here's a very detailed explaination on how to change the cartridges.
HP Video Gallery Replacing Cartridge HP Deskjet 3050 All in One Printer
1 Related Answer
puertobori
  • 7733 Answers
  • Posted on Oct 24, 2010
SOURCE: "cartridge error, printer says to see printer
go to HP Support & Drivers
2answers
I have never used the Photo ink Cartridge #58. It intal pic shows putting it where the black one goes-does this mean I would use the color and the photo one at the same time instead of the black one?
Yes correct.The photo cartridge has to be inserted, where you install black cartridge.The photo cartridge gives finishing touch to the photos which you print.The actual photo comes from the color cartridge only, but for lightness and darkness, the color(ink) from photo cartridge gets used.In photo cartridge there are three color ink, that are light pink, light blue and grayish black.In color cartridge there are three color ink, that are pink(magenta), yellow and cyan( blue).------------- This are the details.Thank you for using fixya.
2answers
When i have installed the new cartridge in Dell 1600n laser printer it shows toner low
Install Genuine Cartridge for Dell 1600n then it will not show any error.
hope this helps
2helpful
2answers
Please show how to replace ink cartages and what number to use.
Please open this LINK and follow the instructions on how to install the cartridges. And here's the supported cartridges details... Click HERE.
Let me know if you need further help..
Good Luck.
Thanks for using FixYa.
1helpful
How to install cartridges
Here's a youtube video on how to install replacement ink cartridges on the Lexmark Pro 205 printer.
If you're doing a new printer install, I suggest you use the installation cd that came with the printer for detailed instructions on how to install the printhead and the ink cartridges. Hope this helps. If you need more assistance, just leave a comment and I'll get back to it. If you want, you can also contact Lexmark Technical Support for further assistance. Thanks.
How to install new cartridge
Make sure the printer is on and not printing. Have a new cartridge handy, as this installation should be done in one session.
Note if the "cartridge is low" or the "cartridge is empty" light is activated on the printer and follow the specific instructions carefully in the document below for each situation.
See "Removing and Installing Ink Cartridges" in the following document:
Epson Stylus Photo R300 - Removing and Installing Cartridges
3helpful
2answers
Installed new hp black cartridge 56 ink but won't print
it shows if your using refill cartridge. & if you r using refill cartridge clear cartridge sensor with soft hands your problem would be resolved.
2answers
E5 problem
E5, says the ink cartridges are the wrong type, not properly installed, or not installed at all. You can't refill those without replacing the chip or resetting the chip. Many refilled cartridges just don't work...
PRINTER HP DESKJET D2360. PRINTER OFFLINE IS NOT GOING ONLINE. I HAVE INSTALLED "CATRIDGE WORLD" CARTRIDGE.
after installed some refill cartridge printer status show offline and just change other cartridge is ok
2answers
5300 kodak eazyshare printer
Well, here is the proper way of fixing or troubleshooting that paper jam error in your printer
Open the printer access door and remove both of the ink cartridge, then remove also the printhead, after that close the printer access door, without those parts. Then it will show a message in the printer screen, "Printhead is missing or has come loose" or "Printhead Not Detected" Install the printhead, just the printhead without the ink cartridges. After that close the printer access door. Then it will show you a message"Ink cartridges is not installed,install ink cartridges". then open again the printer access door, then install the black ink cartridge without the color ink cartridge. then close the printer access door, then message must be " Color ink cartridge is not installed, install color ink cartridge" then install the color ink cartridge." the message must be,"New printhead is detected calibration require, load paper and press start"
Thats the way of overiding the paper jam error message of your kodak all in one printer
hope this will help you guys
by: E.brown
Happy Printing(", )
Kodak AIO tech support 1-800-421-6699
k24674
Grand Canyon Tech
Grand Canyon Tech
