Hello! I can't figure out how to hook my ps3 up to the internet. I have roadrunner thou my cable company. The computer work but I can't seem to figure out how to get the ps3 to work. I have a 60gb so can I go wireless maybe???
The ps3 wifi is very finicky --
While the ps3 scans for a hotspot turn the router off then on so the router aquires the ps3.
Goto settings
Goto network settings
Goto network connection, select enable
Goto Internet connection settings just below internet connection-
Push yes when it says you may be disconnected
Select wired or wireless
For wireless use scan or enter manually
Follow on screen instructions.
Once that is set up return to main menu and go to network near the right
Then once in the internet browser press triangle and goto file and enter the internet address you would like visit.
If all else fail use the ethernet cable to attach it to your laptop. Then run network setup on the laptop and add the ps3.
Connecting your PS3 to the Internet through your laptop.
Connect your ps3 up; use a patch lead from the ps3 to your LAN connection on you PC, and a USB asdl modem.
Properties
Connect to
Show all connections
Right click over your Internet connection
Properties
Advanced
In Internet connection sharing, tick all 3 boxes
Ok
Advance
At the bottom click network setup wizard
Next
(Make sure everything is plugged in)
Next
Tick – this computer connects directly
Next
Next
Tick – only local area connection
Next
Don’t fill in computer description
Leave computer name
Next
Next
Next
Next
Tick - just Finnish
Next
Finnish.
3. Right click over your local area connection this time
Properties
Click on Internet protocol (TCP/IP)
Properties
Tick – use the following IP address
IP 192.168.0.1
Subnet 255.255.255.0
Tick – use the following DNS server
Note: I am with virgin, so on yahoo I put in (virgin DNS settings) and it gave me the following. (Address below).
Preferred DNS server 194.168.4.100
Alternate DNS server 194.168.8.100
Ok
Close
Now on your PS3
Settings
Network settings
Internet connections settings
Yes
Custom
Wired connection
Auto detect
Manual
IP 192.168.0.13
Default 192.168.0.1
Primary DNS 194.168.4.100
Sec DNS 194.168.8.100
Automatic
Do not use
Enable
Press x on the joypad (don’t test yet)
Now on your PC goto your network connections to view all your connections. Disconnect from the Internet. Your local area connection should be connected still.
Once you press test connection, it should connect to the web by its self.
O and if you have zone alarm security, open it up by clicking the tab
Click on firewall
Click main
Set them to MED
MED
Ok test away.
This took me about 2 days of frustration I hope this works for you.
Addresses I looked at
http://au.playstation.com/support/ps3/troubleshooting/failed_internet_connection.jhtml;jsessionid=KOG1SUWRNUZHDS3YIXZSFEWLXBC5EIV0
http://www.virgin.net/helpme/email/questions/1.html
hope it works for you
Okay i use to have the problem till we called playstation and they walked us throught it....
your going to need the cord to connect the ps3 and the modem.
-turn the modem off.
-take the power cord out of the back
-unplug the usb cord from the back
-connect the cord in both the ps3 and the modem
-plug power cord back in
-all the lights will show up and then the orange light will b the only one on
-turn it back on
then you have to go to your network settings on your ps3
make the connection wired and anything that you can make automatic do that.
have fun
Okay well ... i was connected to my ps3 around 7 o clock last night able to play on line and everything ... computer was still connested to the internet but.... now only my computer works and i have changed nothing... i keep trying to connect to my ps3 and ive tryed re doing all the internet connection options on the ps3... got nothing and ive un plugged everything and plugged bak in ... and im stump on wat to do .... ( my computer is wireless and i have an ethernet cable from ps3 to my computer) the router is down stairs im up stairs and like i said already .. it was working fine last night
I've had similar issues. I'm guessing if you have a computer and a PS3, then you have a router hooked up to your cable modem? So, first things first, let's figure out where your problem lies:
1. Unplug the cable between your cable modem and your router.
2. Plug the ethernet cable from your cable modem into the PS3 network port.
3. Unplug your cable modem, count to 10, and plug it back in.
4. Set your PS3 to Easy Network configuration, auto everything.
5. Check if you can now connect to the internet from your PS3.
If #5 fails, then you need to talk to RoadRunner support.
If #5 succeeds, then you're looking at an issue with your router blocking connectivity from the internet to your PS3. This is solvable a couple of ways, but they all involve advanced router configuration, which will be different for each router.
- Enable UPnP on your router (try this first)
- Set up your PS3 to use a manual IP address (probably something like 192.168.1.151)
- Turn off your router firewall
- Setup DMZ for your PS3.
More detailed instructions for these advanced scenarios can be found on the official Sony PS3 forums here:
http://boardsus.playstation.com/playstation/board/message?board.id=psnetwork&thread.id=19016
If your computer is a desktop , get the internet cable from the computers hard drive and connect it to the back of the ps3
At home you can check your Router and your Modem and do things there. With no access to that, an unable to reboot the Router at a hotel you have to check other area.
Im a Computer Engineer. So my nature to figure shyt out like this.
Crazy since its an Unsecure connection. no WEP/WPA and no homepage that you need to accept anything at. Very uncommon for a business to do it that way.
There must be 3 access points that the PS3 could see, since at times it listed different signal strengths.
Some of the Help tips was to Disable Media Center on the PS3. Did that, and nothing.
Also Disable Network cards, then enable it again. nope.
Most of the helps where about Routers and checking on that. My laptop got on easy.
When i did the wizard it would hang on obtaining IP, then time out.
If i put a Valid IP in, then it would give the DNS error. even if i set the DNS, DHCP servers, or had those automatic.
Why can the laptop be so easy but the PS3 not.. :awcrap:
This was the first time i used Internet connection sharing option. Get to the Wireless properties then click on ADV top right.
Check on Sharing.
Then you have to choose 'Home networking connection" this would be Local Area Connection (your ETH/LAN port on your laptop)
Connect a Lan cord to your laptop into your PS3. Set your PS3 to WIRED connection and go thru the Wizard on Easy or custom with the automatic selections.
BOOM your online!!!
This would be good also if someone has a laptop or computer that doesnt have a wireless card and you need to get that system online also.
For Comcast internet and the ps3 - I have the Arris modem that came with comcast internet.
I know this might have been solved a while ago, but if you're going between your computer and ps3, I know how to do it. See when you disconnect the ethernet from the computer and hook it to the ps3, all the setting will stay on it, and this won't work with the ps3. What you need to do is, after you disconnect the ethernet, you have to hit the reset button on the modem. make sure all the settings are automatic on the ps3, and just click on whatever the default options are for everything else. When you hook up the ethernet, it'll connect everything automatically.
Just remember, you have to reset the modem every time you go between the ps3 and your computer.
J
Yes u can use wireless because i have 60gig but mines wireless
Its it verry simple you just need a long wire that you can connect from your modem to the back fo your playstation 3,
-Unplug the wire that is going from the modem to your computer.
-Plug one end to the Modem and the Other to your PS3
PS you wont have any internet on your computer
Ihave a problem wit my dns plz help
Your problem is that your time warner cable router......If the ps3 doesnt recognize it you need to reinstall the data on your computer(of your modem)
TECHNOTOE IS THE RIGHT WAY!!!! I tried it and it worked the first try! Thanks a lot!
Add your ps3's MAC address to your router if it's wifi and reboot both devices.
I have a Vodafone USB wireless Modem stick, why wont my ps3 connect to it? i have plugged it into the usb outlet and ran through the connection settings but it cant seem to find it and connect!
My PS3 connection the last couple of days has been doing this saying error 80130182 check your network settings.
I use an ethernet cable from the modem to the ps3 always has only the last couple of days it's been doing this unable 2 connect online, pc connection works fine but to go online with the PS3 it refers to checking my settings. I've done the auto test and all but still can't detect i get timed out, the green light flashes behind the ps3 where the ethernet cable is plugged in but for sum reason can't read it.
I managed 2 have a game online this afternoon but i tried again 2nite and said the same error 80130182. I"ve never had this problem b4, could it be the new system update could of affected the connection or sumthing? i think it's up to system update version 2.52 i think
SOURCE: Need help with ps3 internet hook up
you can go wireless, but personally wired is better. what router do you have? switch everything off, plug a ethernet cable from one of your ports on router to ps3 then then switch it all on. on ps3 go to settings - network settings - internet connection settings - then select easy - then whether you wanna do it wireless or wired (up to you) then let it do its thing, once its found all your settings you can test the connection.
Have you set up an account on your ps3 yet?
Go to the following page to view a step-by-step interactive tutorial:
http://playstation.custhelp.com/cgi-bin/playstation.cfg/php/enduser/cci/Net_setup_child.php
Thank you for using Fix Ya!
Please rate to overall satisfaction of this solution.
Please let me know if you have any other problems with any other products.
want to set ps3 upto the internet wireless
i have comcast as my ip and i cant get anything right
ps3 wont connect to the internet
the dns wont work
try to connect ps3 via laptop to internet error 8071`0102 what does this mean
Cannot connect to DSL
i have a 60 gb an i cant seem to hook it up for online play
I can't get the ps3 to connect to online gaming the error message said "A connection to the network could not be established. Go to [settings} . [Network settings] and check your settings. (80130182). I have the ethernet cable connected to the dsl modem. I have a 2wire wirless Gateway router with modem. Can you help me?
okay well ... i was connected to my ps3 around 7 o clock last night able to play on line and everything ... computer was still connested to the internet but.... now only my computer works and i have changed nothing... i keep trying to connect to my ps3 and ive tryed re doing all the internet connection options on the ps3... got nothing and ive un plugged everything and plugged bak in ... and im stump on wat to do .... ( my computer is wireless and i have an ethernet cable from ps3 to my computer) the router is down stairs im up stairs and like i said already .. it was working fine last night
help !!!! I am so challenged electronically ... computer in one room, PS 3 in another...how do I connect PS3 to the internet. .... I need clear, simple instructions... with easiest terms for equipment needed...
cant get it hook up with the internet. i have the 80gb
cant hook up the ethernet cable
cant hook up ethernet cable
i have done everything the manual is telling me to do and i am still not getting connected to internet through ps3,i have changed all the numbers through command prompt and still no connection,help
cant get playstation 3 hooked up to internet
i dont know what the SSID code means?
i cant get my ps3 to connect to my cable modem
i fallow all the steps to hook it up and when it tests the connection it cant find the IP address
I have a ps3 and i used to have the internet sbc yahoo. But now i switch to comcast and like now i cant set up a internrt connection
i have a 40gb and i dont have and ethernet cord so i cant get on the internet with my ps3 so im trying to hook it up to my computer so i can get on the internet from my ps3
im trying to hoke up the internet on my ps3 and i cant figure out how to do it i hav an 80 gb
just got highspeed internet and my ps3 will not connect for some reason I have the ethernet cable running from the ps3 to the modem. Whats wrong?
i dont know where to hook up the ethernet cable for the ps3
I have Comcast cable but it wont hook up to my ps3 but my computer work's just fine. Please tell me wats wrong
I have done every thing the user guide toled me to do do but i don't have the instructions for my internet
i have cox cable, how can i hhok up my ps3 to the internet?
I hooked the ps3 up but I don't have the instruction manual on how to hook it up properly
I have wireless internet. i can not figuer out how to hook it up to the net.i am lost. can anyone help me. thanks [email protected]
need to connect my ps3 to my comcast cable internet
ok this is a good one who can fix it? I had an internet connection with an existing computer and as far as I know it was active, running a long wire is impossible given the size of my house and where the inputs are. My room is three floors down surrounded on three sides by concrete block, (wifi hasn't got a chance in hell) I do however have cable that runs down there. My isp is adelphia and i wasn't there when they hooked up the computer. so I don't know what is needed to add another unit and I don't want to have them sell me another modem. Can I buy any cable modem from some store, plug it in and use the existing internet connnection to get my ps3 online.
I have this 80130182 problem too.
I cant connect my ps3 to the internet I have comcast
I need step by step instuction on how to hook up a ps3 to the internet...can anyone help me out?
my ps3 wont hook up to the internet i dont know if i need help with the settings or what but i tried and failed
I don't knnow much about the PS3. My boyfriend just got it and is curious on how to get online. I have read the rest of the comments and questions. I have a desktop PC, it is not wireless. Do I need to call them to get a seperate wireless device from them. If not how do we hook it up?
Please e-mail me back.
i'm having trouble connecting my ps3 wirelessly to tne internet
can i hook up my ps3 to the internet via wireless , If not can i run the USB from my laptop to my ps3. will that work or does it need to run straight from the modum
how do you get the playstation to work to play online can you just hook it up to a laptop
need help with ethernet coird
i hooked up a netgear wireless-g router to my desk top computer to make the internet work on the lap top but my ps3 still doesnt have internet what im sopposed to do
well im a child only 12 years old, and my ps3 works only wit the wire and every time i try to hook it up wirelessly it says my connection fail so idk wat to do so plz help me to get my ps3 on line wirelessly, like give me a way to do it easely!!!!!!!!
I HAVE A PLAYSTATION 3 CANT SEEMED TO HOOK UP THE CABLE INTERNET TO IT MY COMPUTER WORKS FINE
i have no access to an ethernet connection where i live and all i can use is a dongle from a telephone company but that will not connect to my PS3 i was just wondering how i cn connect my ps3 to the internet?
iam tying to hook up my ps3 to the internet what do i need
i dont know how huke up ps3 to internet
i hooked my ps3 to the rouder with a ethernet cord and went to the game(ghost recon atvanced warfighter2). i pressed online and it sed to test conecton .so i went to settings and went to test conection and it said ip address succsesful.but on enternet conection it said failed. plz plz help me!!!!!!!!!!6-7-08
i set my ps3 up for internet whent through all the settings and it said ip sucsesfull but internet had failed what do i do plz plz plz help me
have wireless router but cant connect to internet
I have a wireless router and I can't figure out how to set up teh settings on the PS3...after I set it up it says obtain IP address failed.
how do i hook my ps3 up to my computer to download upgrades
ps3 won't hook up to the wireless internet
i have high speed internet thru verizon wireless. I have a um 150 usb hooked up to my computer, how do i get my ps3 on line thru this or is it even possible
my internet works fine on the computer but when i hook the ethernet cable up to the ps3 it wont obtain an ip address?
I typed in all of the codes on the back of my wireless router. I am primarily prompted for an SSID code; the model number of the router was the only number that was accepted. I'm not sure if that's the number that actually works but I was able to proceed to another WEP security code that I was prompted to enter, but none of them worked. Connectivity could not be established. I have roadrunner cable through my cable company (time warner) and I have a D-link wireless router. What codes do I need? Help!!!
my internet works to my computer but i just can't figure out why my ps3 want hook to the internet it keeps telling me that connection failed
i have the same problem on my ps3 ,can you help me
i just want to know how to hook it up to the internet.
resetting the modem
when i try to hook my ps3 to the net it is asking for a ssid what is that
cant get my ps3 online
i would like to get online but it keep saying press on aoss. i dont what that is
every time i hook it up right when i go to the ps3 shop it says no e-net connection what do i do??????????????????????????
its don't let me go on web i got timewarner
i can't hook my computer up to my ps3
i have time warner cable and a netgear wireless router i dont no how to hook up my ps3 to the internet, but my computer has the internet.
I have Cox and when i do the settings on the PS3 it fails on IP address? it would not generate an IP address..???
Help....
It just wont work. It detects my connection when i unplug it but when i test or try to play online it just dosen't work. I have look at a thousands site's to get help but i can never find anything.
cannot connect due to cant find ip address when connecting, i took ethernet cable from computer and hook in ps3. just says go to setting but that doesnt help much, what should i do?
im a 13 old boy who "does" has everything... i just need to know how to get my ps3 wirless and hooked up to the internet.... see i id have online but as i went through my settings i accindentely(sorry for spelling) reset the settings.. now i have nothing i could use help really badly bcuz i was really good at the games online and i had really kool friends but i lost it all... so if someone could help i would appriciate(again sorry for spelling i dont have time to look up words) it so much
i need help in the internet
my ps3 internet wont come on because it says it cant find my IP Adress
cant figure it out
i cant connect my ps3 to my network
I connected my ps3 to my laptop via ethernet cable. My laptop uses a wireless cingular connection and it sees the ps3 but won't allow it to connect
i have a alltell wireless aircard with the same problem. it found my ip address but disconnects me from the internet while checking for the connection.
and u tell me what to do next
My internet worked during the day but had a problem during the night. First time this ever happened.
I have a wireless port in i put it in my ss3in it wont hoke up
i cant get on the internet using my playstation 3
My PS3 is not connection to the internet.. Everytime I try to connect to the internet. It tells me that The connection to the sever timed out and it gives me numbers.. What can I do.
internet is saying theres a proble with the dns but im online on my computer
I will go to the game bring up my phone select multiplayer and it just tells me to go to settings network settings 80130182.I do that and put in all the stuff i have to put in and I do connection test and it says IP address timed out.then I go to the game bring my phone up press multi player and it says right here.
error 8001000A
i have a ps3 (60 gb) and i have roadrunner. but on my computer. but when i try to go wireless i cant get a connection. im sure im doing it correctly because when i was out of town i sucessfully connected at the hotel i was staying at. the wireless scan doesnt even show my service for any type of signal strength.
well i just dont know how to hook my ps3 to the internet
I havn't been able to get online on my ps3 since I got it. when i try to get internet wirelessly it can't find my internet connection even though i can get online on my computer, labtop, and my psp but not my ps3. I tryed connected to the router form my ps3 with an ethernet cord but it keeps saying its not even plugged in. then i tried to connect to my labtop using a differnet ethernet cord but it still says its not plugged in, and almost always it says a connection error has occured error (80010201). Can you help me get online.
well i tryed to connect the internet too but i get into network settings then internet connection under settings then it says easy so i press it, but then a screen for setting options pops up such *** PPPoE, proxy server and IP....
then i dont know wat too do after that
i have the same problem i dont no wat the hell those codes are
I have a playstation 3 and roadrunner thru TW. How do I get connected to ethernet wireless. Do I need cords or boxes or what. Thanks
i just need to know how to play games online, like call of duty 4
I have the router hooked up and everything, but my PS3 can't find it.
You can easily fix that with a repair guide from www.PS3RepairsGuide.com
CANT GET PS3 WORKING WITH HOME INTRNET CABLE
same
i am trying to hook my playstation up 2 a wireless router butit is asking for an ip address so i took the ip of my laptop an thought it wud work with that but iv had no luck.
its asking me for ip address
i have comcast cable and wireless internet.im having problems trying to play multiplayer on grandtheft auto 4 can any one help?
da damn internet wont work
I have Comcast wired internet and when I test my connection it says I have a DNS server problem.
i dont know how to hook it up to my computer to play online and dont have wireless
yes i do help please i mean i have a 80gb and well....... it says to go check ur settings help!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
i have high speed cable for my internet and my computer works but when i hook up the ps3 it says something about the ip address...it has worked briefly for a while then my connection is lost
I have the same problem and I have an 80G ps3 and can't find a solution. I have a Ethernet cable but have dial up and don't know how to hook it up and play. HELP!!!
i just got a ps3 and cant seem 2 find a way to set up the internet please help i have a 60 gig
how do i hook my ps3 up to the internet??
hey,i have a ps3 but i do not know how to hook up the internet i have cox cadle and internet
I have the the same problem my Ps3 is not going online and i tried to hook it up to the system and it did not work wat should i do?
im trying to connect a ps3 using national broadband access thru a blackberry is this even possible
i dont no how to hookup the internet for my ps3
i dont no how to hook up the internet for ps3
hook ps3 up to internet modem
cant find IP ADRESS.
I can't figure out my SSID when it ask me for it. So I can't get to online play.
I just installed a wireless router for my playstation 3, do I also need an adaptor as well?
i hoop up my ps3 to a usb cable and it doesn't work,but if i hoopn up the same usb cable to the computer it comes online.I have a 80gb ps3 what do i do.
i cant hook it up
can't find IP Address
can't find a ip address to a dsl
I cant find the aoss buton on the PS3
I have the same problem, that you had how do i fix it?
test connection fails as if it doesnt read the router
WONT HOOK TO INTERNET
ip adress is never obtianed in time
does anyone have step by step instructions on how to connect the ps3 to the internet via dial-up?
we bought a ps3 from craiglist but the multiport is not working do you know how to fix this problem.
same thing 80kb
How do you hook up your PS3 to the internet?
tryin to get the ip address to work
i cant get my internet to work for my ps 3 need help
NO ONE ISNT HELP ME SHOW ME HOW TO HOOK UP DSL ANDS ROUTE MYSELF
trying to hook up wireless connection to internet
I am trying to connect my playstation 3 via wireless I have roadrunner cable on the second floor and the playstation is on the 1st level I dont want to runner cables all over the house what do you suggested
hook up internet
HOW DO U GET PLAY ONLINE?
help me i have it hooked up to my modem but it still wont work
don't know how to hook up the internet connections
my ps3 wont connect to wireless on talktalk but it will with the ethernet cable it say error 80130182 any help
can go on the internet but not on the ps3
Got a router! Plugged it in and the computer works,but the playstation doesn't!
trying to hook playstation 3 to internet
i dont get how to push the AOSS buttob where is it?
ps3 times out when obtaining the IP address. Using a ethernet connection.
help me
i need an easy way to hook up my internet cable to my ps3 but my ps3 is upstairs ps3 80 gb
I have internet with my computer but i dont with my ps3 how do i get the internet with the ps3
i am lazy and cant get my ps3 to hook up to the internet my computer works fine but when i try and go on the internet with the ps3 it says the server timed out. how do i fix this in an easy way
It keeps saying Internet Connection failed and is saying that it is an DNS Error....Internet works fine with my ethernet cable which is how im trying to hook up my PS3
when i test my internet it times out on ip adrees
what do i supposed to do it keep saying this is a dns error.80710102
i try to get in ternet on my ps3 and i have a laptop and a router and i try to get wired connection and it always says failed to obtain ip address
how do you hook up the PS3 to wirless internet
my playstation3 wont connect to internet
i have the same problem when i changed to comcast it just dont work and its wired
I have a wierless conection and it works on my laptop but my PS3 says failed to obtain ip address when i try to connect.
i hook my ps3 up to computer but nothing happens
ok My ps3 network is giving me every kind of problem first when i manuelly put my ip address and everything else, and then press test connection it says dns error fail. But then i do ip address atomatically and do test connection, it stalls for about a minute until it says ip address has timed out. so there no way of me knowing what the best solution is. Please help me.
How can I connect my PS3 online ?
how do i get my ps3 hooked up manually to a wireless conection?
hello idk how it says that my network connection is wrong when i press up for the cellphone on there
it keeps saying DNS error it sucks motherfuckin *******
it is tickken me offfffffffffffffff
My computer is wirelessly connected but my ps3 will not connect
Solution link . . . www.SonyPlaystation3.com,
go to your network settihgs 0n your PS3 setup wireless go to your router and add device
