Item is brand new. Assembled, mounted to wall. Reading from manual, we did step by step instructions for the first time using/turning on fireplace. The flames never appeared. The colors never appeared. Hard to know if the dimmer switch is working as there is NOTHING in view to dim. Heater works. Timer works.
SOURCE: Chicagao electric fireplace heater doesn't work
MY HEATER NOT WORKING,BLOWER AND LIGHT COME ON NO HEAT
SOURCE: My electric fireplace model # HEF33WDG, the heat
go to ebay and put in electric fireplace heater parts, the flame motor is around 20 bucks, and the heater element around 50 bucks Good luck
SOURCE: Gas fireplace pilot flame won't stay lit.
Hi , you can try and pull the panel on the bottom of fireplace out and check the adapter in fireplace. Sometimes they go bad. When you open in also check to see if there is an adapter plugged in and a option to use the battery operated function. If this goes bad the pilot will not stay lit.
SOURCE: motor in dimplex fire/heater not turning
Hello. It could be possible that a piece or some of the foil that gives the flame effect has fallen down on the motor, that creates the heat. This could be causing the noise. I would not think this is an electrics problem.
I would ensure the electric fire is disconnected from any power supply and either open the heater myself or get a electrical specialist to have a look. Then you will see exactly what is happening. A piece of foil may be visible which is catching the motor.
If you decide to tackle the problem yourself write down how to put the heater back together as you take each part out. These parts would be covers etc. It can easily get confusing. That is important.
SOURCE: electric fireplace does not heat
I have a cheap electric fireplace bought in SuperCentre store-heater no longer works. It says its a one piece system. Can these heaters be replaced or repaired(probably made in China) or am i better off scrapping it and buying a new one?
Hi do you have the owner manual to this. I purchased one just the unit nothing more and don't know much about it thanks
Do u still have owner manual I purchased just the unit no remote nothing else and don't know much about it
Where can I get a heating element for a Great World fireplace heating element for a Intertek 4000755 model # GW-5078
