It seems you are using a print server to connect the printer 1280 to your LAN. Uninstall the printer software and printer server driver. Connect the print server to the network and first re-install the print server driver. Then connect the printer to the print server and install the printer software. Refer user manual for assistance. Bot the print server and printer software should be compatible with your operating system.
I Have A Epson PLQ-20 passbook Printer and it is connected through USB cable. after successful setup when i give print command to the printer it is not responding and nothing happened.
It seems that either the drivers are not installed for this printer or the printer has not been selected in the word processor.
First insert the CD that came with the printer in the drive and install the driver for this printer. reboot. and connect the printer and allow Windows to detect it and load its drivers.
Now second, open the document that you want printed in a word processor and give the print command. Here you will find an option on which printer to print on. Select this printer and get the prints.
whaen you give print out choose the proper printer and remove unwanted printer form the system .and when u giving the print command make sure you choosen proper option like slides,handout and the current page accordingly give the option and see how is the print preview.
check the driver, is it installed properly...or the cable..try reinstall the driver, or maybe you set a wrong default printer its just software problem
Delete Queued Print Job
If a print job is corruptand does not print clearly, does not print at all or is preventingother queued jobs from printing, delete the queued job.
On the Windows taskbar, double-click the printer icon located to the left of the time.
At the Printer window, select the print job, under 'Document Name' column, to highlight it.
From the 'Document' menu, select 'Cancel'.
Repeat steps two and three to cancel another print job.
Ifthe print job cannot be cancelled or will not stop printing, shut downthe compuer, disconnect the printer cable and then restart the computer.
Close the Printer window.
Shut down the computer.
Disconnect the printer cable (USB or parallel cable).
Restart the computer.
If a message window appears asking to cancel printing, select 'Yes'.
Verifythe printer icon no longer appears on the Windows taskbar. If the iconappears, double-click it and cancel the remaining print jobs asinstructed on steps two and three.
After all print jobs have been cancelled, reconnect the cable to the printer and then try to print again.
Ifthe print job does not complete, it may be necessary to disconnect theprinter cable, power off and on the printer and then reconnecting thecable.
Your DHCP server will keep track of which MAC Addresses have been given what IP addresses. From there, find the IP address of your Print Server. Ping the IP address to confirm IP connectivity between your computer and the print server. You should then be able to upgrade the firmware.
