Computers & Internet Logo
Clara Chizema Posted on Sep 13, 2014
I can not receive emails on my web - Computers & Internet
Noah Denza
Level 1:
New Friend:
  • Contributor 35 Answers
  • Posted on Sep 13, 2014
Noah Denza
Contributor
Level 1:
New Friend:
Answers
35
Questions
Helped
8254
Points
66
Either change your browser or change to a different email host. There is yahoo, gmail, aol, etc.
I cannot receive email on my blackberry 9300
RIM uses push technology. Email has to be set up at their end. I think you can do it via the web. Then your provider handles your email to your phone.
How do I validate my Email address?
normally a web site will send you a validation email to a valid email address that you supplied. You need to go to the email and find the message sent to you , check also in spam or junk folders and then open the email and look for a hyper link to click on that will open the particular web site and register you have received the email message .
Why isnt my email account receiving emails?
Are you signing in on the web, or using a program you downloaded?
Microsoft Web Access won't send mail
If you are trying to send or receive an email in Microsoft Outlook and the password doesn't work, you can check a number of different things. Microsoft Outlook validates your email account with your email provider using various settings. Once it has validated your settings, it will send or receive email. It is not only useful to set up your email correctly but essential if you wish to use Microsoft Outlook.
Gather all of the email settings for your email account. These will be located on your email provider's website in an FAQ or support section. If in doubt contact your email provider to provide all of the settings. Look for any of the following terms: POP, SMTP, IMAP, SSL, SPA, server, and port number. Make a note of all of these. Determine when the problem exists. Check if the problem occurs when sending an email, receiving an email, or both. If the password error only happens with either sending or receiving, this narrows down the source of the problem. Click "Start," type "Outlook" and press "Enter" to open Microsoft Outlook. Click "File > Info > Account Settings." Select your email account and click "Change." Click the "Incoming mail server" field, if your error was when receiving email but not sending. Enter the full "incoming mail server" address as provided by your email provider. If your email is "IMAP" then change the "Account Type" to display "IMAP." Click "More Settings > Advanced." Make sure that the incoming server "Port" number is the same as your email provider stipulates. If your provider requires SSL, then click "This server requires an encrypted connection (SSL)." Click "OK." Click the "Outgoing mail server" field, if your error was when sending email. Enter the full outgoing server address. Click "More Settings > Advanced." Make sure the "Outgoing server" port is correctly set. If your email provider requires encryption, then select the correct type from the drop-down menu. Click "OK." Click the "password" field and make sure you have entered the correct password. If your mail provider requires "SPA," then click the "Require logon using Secure Password Authentication (SPA)" to enable it. Click "Next" and then "Finish." Your password should now work. Hope it helps.
What do I do to my lap top or kindle to receive emails
There is no specific email client on the Kindle so you can only receive your emails via the experimental web browser and using a web mail service to access your mail.
I can send e.mails from work from my ipnone 3gs but nowhere else???
Base on your question, am I correct? you can send email and receive emails from your Iphone, no problem at all. That mean your Iphone doesnt' have any problem with email.
Elsewhere, such as you use web-base email, you log on email from website and you couldn't send emails from the website??? Is that right? Or you have a email client software, such as: outlook, thunderbird, .. and you can't send email from that.
In my opinion, if you can send and receive emails from Iphone then the email server is ok, your Iphone is working well with email. Problem is the elsewhere you use to send and receive emails, maybe the setting of email client software, maybe the compatible of web browser. If you could, you try the setting, make sure the ports is correct.
Hope this will help. Keep posting your question. I will follow up. Thanks for reading.
I CANNOT OPEN OR SEND EMAILS
  1. Cannot send email but able to receive
    Typically, POP based email accounts have the same address for incoming and outgoing email servers. However, sometimes the email service provider might have a different outgoing email server which has a different username and password (next point). Please check with your provider for details if you cannot send email but can receive.Is the outgoing email server address correct?
    The outgoing email server (SMTP) address needs to be correct for you to send messages from the account. You can find this information in the email you have received from your web host.
    The outgoing email server address would typically be based on your web site's address, unless the server has been configured differently. Thus, if your web site's URL is www.my-web-site.com, the outgoing email server address would be either my-web-site.com or mail.my-web-site.com (substitute my-web-site.com with your actual domain name).
I am no longer receiving email from "psusd.us". I
The email account structure comprises computers network structures. Malfunctions related with emails also traceable to network structures have several conditions to attain functionality. For example, an email account once established requires the component hardwares softwares together with user request to restore and keep functional. Email account malfunctions are resolvable by contacting the web internet technician either as least telecommuncations attainable from the senders structures of computers. Alternately the receivers component of computer structures once encounted malfunctions least makes telecommuncations. Notifying the web experts initiates the restore process.
Feb 18, 2011 • Yahoo Mail
Can't use either Microsoft Live Mail or Lookout Express v6 with Belkin Router. Can't send or receive email Can you tell me what the email setup is for either one? Both email programs probably use the same...
Ask COMCAST for the names of their POP-server and of their MAIL-server, and configure Outlook Express to use those names.
Microsoft Live Mail is "web-based" -- all you need to do is to web-surf to their web-site, login, and click "send/receive" or click "compose" and later "send".
HTC S620 Email Notification
Hi There, I think if you are using a web based mail - like Yahoo - it will not count these inputs or outputs - do you really want it to? I have 6500 unopened emails on my desktop system! If you can access email and web you are doing fine! Brian - a learner on this like you- share notes!
Grand Canyon Tech
Grand Canyon Tech
