Need some help on how to turn down the oven flames on a new stove
Please help me step by step in how to adjust the flames lower its a new stove and the top burner flames are fine, just the oven is burning too high, thanks
Is this unit set up for natural gas or propane? New stoves usually come with ORIFACES for both gasses. They would install between the on/off knob and the burner tube under the stove top. They may be tapped to the under burner area of your stove. If you lift your top stove cover you may find them. If you don't find them, you may need to purchase the correct applications for your stove. GOOD LUCK FRIEND.
Use a manometer to insure lp gas pressure is correct. The regulator for the stove may need adjusting. The air mixture adjustment may not be correct for PL as well.
Remove the front panel to find where the gas injectors enter the burner tubes you will see they are cut away and have a screw holding an outer ring which is adjustable, open them up more to get more air in .
If you are getting soot residue, it could be a number of things, First, is this a natural gas or propane oven? If you bought an oven to be used for propane, it may need to be converted from natural gas to propane or it will soot everything up. 2nd, have you recently spilled food/liquid onto the oven burner? If the burner holes are partially plugged, the remaining holes will burn large yellow flames and soot up the oven. Check the burner flames, they should be mostly blue with little to no yellow tips. Also make sure the oven burner flames are not too big. They should never exceed the width of the flame spreader pan directly above the burner, in fact they should be less than half the width. You could also have other issues like improper air shutter adjustment to the oven burner or very low regulator pressure, but most likely it has just been spilled on recently.
You need a Gas tech/plumber there urgently!!!! If the gas jets in your oven had not been changed to accomodate LP gas then the orifice on your existing jets are still to large in diameter. In other words your using Natural Gas jets ( lower pressure jets) for Lp which has a much higher pressure than Nat. gas, this can be extremely dangerous, & could cause major problems. Again I strongly suggest you contact a Gas tech/Plumber & do not use your oven until it has beeen checked by a professional.Good luck
You mean the flame is low. You need to clean the burner jet hole orifice and also check if their is a gas pressure regulator which you can adjust the pressure a lithe more higher.
Yes you can make adjustments but you need a thermometer to set it accurately, you can buy them at Wal mart for 4 bucks. You will need to see if the thermal bulb is located in the flame, if not you will have to move it when it's cool. Some units have a screw to adjust the temperature some use a sliding tube to adjust the heat you will need to look at the stove to see. If you have the owners manual it will help, sometimes the thermal bulb goes bad and the temp control has to be replaced.
