Arc (mma) works but can not get the mig to work... have not yet tried the tig....
I found a forum addressing the welder you mentioned. They are amused, as you will be, by the manual. https://dl.dropboxusercontent.com/u/11148130/MishtoWelder/MIG200.pdf
It is ridiculously useless. Try taking your welder to a high school shop teacher or find a local hobbyist welder -- because welding supply stores hate these Chinese boxes that cut into their sales and will not be helpful.
SOURCE: I have lincoln 125 mig welder that seems to want
Re-adjust your tention wing nut, or make sure you have the correct groove on the feed wheel for the size wire you are using. also, if you are using an extention cord that is to small or to long it will cause it to skip.
SOURCE: i have a century 120v 90amp mig welder model
It could be the ground clamp disconnected.
the polarity could be set incorrectly.
SOURCE: I have a lincoln 135
Hi, well I see these type of problems all the time, and if it will NOT strike and arc, then most likely the main output semiconductors have failed... perhaps when you changed polarity? It should strike an arc regardless, but in any event and in this case yes you will need to take it ion for "Service" there are NO DIY "Bits" as it were. Always ask for a "Quote" before allowing any repair work to be undertaken.
Internal fuse inline with the transformer output to the gun.
Follow this Link:
http://www.clarkeservice.co.uk/manuals/mig_welders/migpro90_150te.pdf
Let us know if it was the right one.
