WANT TO REPLACE the current microwave, but want to fill the space over the stove.
Determining the cubic feet of any given appliance, Microwave, Oven, Freezer or Refrigerator is quite simple.
Follow these steps.
Open the door of your microwave and measure the length, width and height in inches of the interior cavity.
Multiply the length by the width by the height using a calculator to get the total in cubic inches.
Divide the cubic inches by 1,728, which is the volume of a cubic foot. The resulting number will be your microwave's measurement in cubic feet. You can also use an online conversion calculator to simplify matters
Hope that helps
SOURCE: Ge Microwave space saver over range working but
It is a good possibility that the stirrer has failed. In the top of cabinet is a round cover,there is a small round plug in the edge of it,pry plug out and put it in safe place,rotate the cover < twist locks > gently let it down and stirrer will be either setting on cover or still attached. If you notice any damage< it is a round aluminum disc that is flat > then you need a new one. If you don't see any damage put it back in < put in hole and turn until you feel it line up with shaft and push into place,< gently >.Make note of position and put cover back on < stirrer does not lock on shaft so you have to hold it up until you get cover under it in most cases. Run a short cycle and remove cover to see if it turned at all. If not the motor is bad < turns stirrer during operation>. This is the first time that question has been asked of me and it is the only thing that I can think of if it heats glass and not food.
SOURCE: GE JVM130K004 space saver microwave not working
The magnetron is overheating, and the magnetron thermostat is tripping, interrupting power until it cools back down.
This is to protect the magnetron from being destroyed from overheating.
It may be that the internal cooling is not occurring or the magnetron is failing. Cooling can be compromised by:
- failed or failing internal cooling fan
- blocked air inlet or filter
- outer cover not installed correctly
There should be a "mini-manual"
hidden inside the unit behind the control panel or hidden on the left
side
behind the grille, which is very helpful when troubleshooting, &
testing.
At
our Web site, we have a
video available
showing how to remove a typical over the range control panel assembly in
under 5
minutes.
You can find
links to helpful exploded view diagrams and part ordering help
here.
I'd recommend that your bookmark this link to your favorites.
We're
happy
to help you with free advice and we'd appreciate your
thoughtful rating of our answer.
Testimonial: "Thank you -I decided to replace the mic. By the time I pay $75 just to send someone out, + labor & parts to repair I found a replacement GE for $199"
SOURCE: GE space saver Microwave not heating
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
SOURCE: GE model # JVM1850WD-002 Microwave
Please read the solutions in below website.Check all the things listed in below website.If still problem persists then you need to call for service
http://www.repairfaq.org/sam/micfaq.htm#micnhono
In this there is a topic called as No heat but otherwise normal operation.Check in that topic
Thank You
