This phone loses wireless connection, I reset it on network settings, ok for a day or so, then reverts back to 'not connected' can you help?
SOURCE: iphone does not connect to wireless networks anymore
HI,
It will cost you anything between $100-$150.
If you need anymore help let me know.
SOURCE: Wifi not connecting to wireless network where as other devices r.
Is your wireless network password protected? If so did you put that password into the iPhone properly?
SOURCE: Unlocked GS can't locate wifi connection.
yeah u can , and u need a software for your settings
SOURCE: My wifi doesn't connect to
Ad-hoc is a computer to computer connection.
You need to change the wireless configuration to Access Point (Infrastructure) mode with encryption.
Your wireless card
in your computer or laptop needs to be configured with the router's wireless
settings eg. the SSID and encryption key
The encryption key
(network key) is in your wireless router, without this key the wireless router
won't allow the computer or laptop to connect to this wireless router.
The WEP, WPA, WPA2
encryption key is in your router's wireless settings. Log into your router and
got to the wireless settings, you will need to get the SSID and the encryption
key. Then go to your computer or laptop's wireless card and configure it with
the router's SSID and encryption key, so it will then connect to the wireless
router and the Internet.
To secure your
wireless network from unauthorized access,please click on this link and follow
my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security.
Print the network
settings page to identify if your printer is connected to your wireless
network:
1. Press Setup on
the printer operator panel.
2. Press the right or left arrow button until Network
Setup is displayed, press OK.
3. Press OK at Print Setup Page.
4. Press OK when prompted to Load Paper.
5. Press OK. The network settings page will now
print.
Check the Network Card Status, SSID, Trouble Code, TCP/IP Address.
SSID should be the name of your wireless network. Otherwise, you may need to
reset the printer's wireless network settings.
How to
reset network settings:
1. Press Setup.
3. Press the right or left
arrow button until Reset Network Adapter Defaults is
4. Press the right or left arrow button to display Yes,
pressOK.
Once the Wi-Fi light turns on to solid orange, run the Lexmark
Wireless Setup Assistant on your Mac.
