Where can in get the parts to fix this problem
Like most pumps; air, hydraulic, etc. there is a one-way valve with a ball or flap mechanism. If a small particle gets stuck preventing it from sealing, it'll leak pressure preventing it from building up. an easy way to try to clean this valve is to apply some air pressure to the hose end of the sprayer while operating the handle. your instruction booklet may cover this.
SOURCE: immediate pressure loss
your dip tube inside the tank has come loose or has a leak near the top. instead of fluid being pushed up the dip tube into the wand hose the air in the tank is just escaping. You will have to remove the wand hose and figure out where the leak is and fix the dip tube.
SOURCE: Tank will not pressurize after pushing the pump
the reason it might not pressurize is there might be a hole in your tank or hose to the spraier itself if it has holes in the hose get a new one put it on the tank and handle. if hole in the tank duct tape it or seal it with a sealent. but it wont pressurize with a hole because the air comes in and out of the hole. hope this helps you
Never seen one of this type and if its all plastic which i suspect then its clean the nozzle and if that doesnt work then its the recycle bin iam afraid as a lot of these cheap things do not come apart without breaking
SOURCE: why does Pump not build pressure
probably bad seals or ring or the relief valve is stuck open
