Need directions on how to use combination. Model # 5056 & key 3224
Usually a standard practice:
1. Turn dial RIGHT (clockwise) three times to clear settings.
2. Start the dial on 0 (zero) to dial combination,
3. Turn dial RIGHT, passing first combination number FOUR (4) times and
stop at number on fifth time around.
4. Turn dial LEFT, passing second combination number TWO (2) times and
stop at number on third time around.
5. Turn dial RIGHT, passing third combination number ONE (1) time and
stop at number on the second time around.
6. Turn dial LEFT, to the last combination number and STOP.
7. Insert the key in the lock and turn key RIGHT to open.
Sentry Safe Product Manuals
SOURCE: Forgot Digital Combination of Sentry Safe Model #SO500
https://www.sentrysafe.com/customerCare/retrieveCombination.aspx
They should be able to help. I would try calling first, to avoid paying the $12 to retrieve the combo, but with the serial number of the safe, they SHOULD be able to help you over the tele.
SOURCE: sentry safe V530
may have been 8 bucks , but it's 12 bucks now.
check out www.sentrysafe.com ,
look on right side menu for "keys" and/or "combination" .
SOURCE: know combination, but cannot open sentry safe 1250
If you know the combination:
1) Turn the dial to the left a few complete rounds, then stop on 1st number.
2) Turning the dial to the right, pass up the 2nd number once, then stop on it on the next round.
3) Turn the dial to the left directly to the 3rd number then stop.
The handle should open now.
SOURCE: can't open combo/key sentry safe.
You need to contact Sentry, they will send you an emergency unlock code.
Number in US is 1-800-828-1438.
See also:
Lost combination or keys
Replacement Keys and Combinations
Sentry Safes Key: 2 Replacement keys for sentry fire safe
SOURCE: How to open Sentry V330 with combination and key?
3 Digit Combination Lock
31-10-31
If this still does not open the safe, refer to the following page for additional different types of Sentry Safe models:
http://www.sentrysafeshop.com/kb_results.asp?ID=15
