Temporary fix, I disconnect battery and reconnect to get Them to function, then after a short time they fail again. Can you help with a fix?
SOURCE: I have a 1998 Mercedes
Probably a short in wiring. Vibration are causing contact to go on and off, check circuit and connectors with a tester.
SOURCE: 1998 Mercedes Electrical / Electronic Issues
From all indications, most of your devices are controlled by a common module. This would be similar to the engine management computer but has the responsibility for all those mentioned and then some. if you would notice, most if not all are non essential to the engine's performance. Initial suspect would be such a module and/or the sensors, connectors to it. Being such as multi input and multi output, it is perhaps to your advantage to seek the services of a qualified professional. If you are considering a DIY (do-it-yourself), then access to a full service manual would make things doable if not easier.
Often this control module would be under the dash or on any of the kick panels.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
I never know when the malfunction will accure, by disconnecting the battery and reconnecting the battery it clear up and all is funtioning, I seem the disconnet needs to off for shot period in orer to wok,
my typing is not my talent, sorry
