Just need a direct answer to a simple problem and also the opposite of that if the # is greater than 1 does the decimal point and a 0 go at the end of it?
SOURCE: Decimal point
You need to put your tab where it says K*A and set that to A (it is the 3rd set of buttons) and then you need to go to the 5th set of buttons that show F 6 3 2 1 0 and set this to 2. Hope that works :o)
SOURCE: The calculator won't convert fractions into decimals
Are you using a ti-89? If so, check your mode settings and change Exact to Approximate.
SOURCE: I have too many zeros after the decimal point.
If got to do with the mode settings. Usually MODE fix in other lower version of calculator. The combination can be MODE FIX 0 for no trailing zero's if MODE FIX ONE then if will 0.0 or one zero then shifting the settings to NORMAL mode and at DEG mode.
SOURCE: Setting the default value of my calculator to display decimals
Since you bent on deactivating the very features that make your calculator so versatile and so powerful, here it is.
Press [SHIFT][MODE][2:LineIO] and you will see no more fractions, nor radicals etc. You asked for it.
Hope it helps.
Testimonial: "I bought the calculator because it was on sale and I like Casio calculators; not for its fractional abilities. I can easily switch it back now. Thanks"
SOURCE: I have a SHARP Compet
With this type of calculator, you have it right to display 2 decimals. As far as for is to dislay 5.10, you will need to actually hit the decimal point where you want it in order to display it that way.
