Roland Cube Street - Battery Powered Guitar Amp Logo
b
brian hitt Posted on Sep 12, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Do i have a blown fuse if I am checking 2 small fuses that are on a circuit board. one is 1.6 amp 250v and the other is 160ma 250v and the 160ma fuse is the one testing 1.4 and the 1.6 amp fuse is tes
I am checking 2 small fuses that are on a circuit board. one is 1.6 amp 250v and the other is 160ma 250v and the 160ma fuse is the one testing 1.4 and the 1.6 amp fuse is testing at .4 which is what my multimeter shows when i simply press the contacts together.
richard vreede
Level 2:
Sergeant:
  • Expert 432 Answers
  • Posted on Sep 27, 2014
richard vreede
Expert
Level 2:
Sergeant:
Answers
432
Questions
6
Helped
112239
Points
621
They have a restorside, a bit , that's why you have fast and slow fuses. But if they were dead, then the resistant would be infinite, so
no problems with both fuses.
gr. Richard
I have an Avanti gfit motorised t/mill.It has blown a fuse that is located on the circuit board.the fuse is rated 250volt/10amp.Where can I buy some more fuses, and how do I get a service technician to...
A sudden load can be enough to cause the fuse to blow rather than a short. Replace the fuse either with a 250v 10A Slow blw fuse or us a 250v 15A standard fuse. If it still blows then there is a definite fault. Motor Loading from lack of Lubrication etc.
Or a wiring short. Fuses are available from many suppliers. The shape of the fuse being used and how it clips into the board will be import and. Take a sample or an iPhone photo with you.
2helpful
4answers
Brookstone Wafer-thin CD with MP3 player circuit failure...why?
My manual shows 4 different fuses.....The Outside SubWoofer fuse is a T2A 250V....Inside the Subwoofer There is a T4A 250V....I couldn't see the other fuse, and I assumed it was the same, then I find on the inside of the manual there is also a T1.6A 250V and a F200mA 250V
I have been trying to call Customer Service at 1-800-846-3000 but it's always busy.....
2helpful
2answers
Burned our fuse in circuit board
it is a 250V 15 amp. clip the fuse off the wire, close, and solider in a new one. Terrible design. LG should have to replace free or be sued !
3helpful
NAD C270 amp won't switch from red power/protection to green.
The AH may denote "slo-blo" style as opposed to Fast-acting
A fast-acting fuse will look like a single strand of wire ( maybe wiggly looking) ..A Slo-blo will have an element in it and a spring
2answers
Philips 60PP9202/17F Fuses are gone
I can't believe he pulled them all, but here's a list of all the fuses and their ratings from the service manual:
S 1000 Fuse, T 5A IEC
S 1300 Fuse/Clip, 5 Amp, 250V
S 1801 Fuse, 2 A, 250V IEC
S 1804 Fuse, LT 1A, 250V, IEC
S 1805 Fuse, LT 1A, 250V, IEC
S 1700 Fuse, 2 A, 250V IEC
S 1701 Fuse, 2 A, 250V IEC
1003 Fuse, 500MA, 50V, UL
3helpful
5answers
Fuse blown
the fuse will always blow if there is a shorted component. the horizontal output transistor may be the most likely culprit, if you are not a technician, have it service by a qualified one.
Top Roland Audio Players & Recorders Experts
 Grubhead
Grubhead
Arnie Burke
Arnie Burke
ADMIN Andrew
ADMIN Andrew
Are you a Roland Audio Player and Recorder Expert? Answer questions, earn points and help others
