I would appreciate any information on this code that anyone can provide. Thanks!
"EE" means that the scale has been overloaded. Try placing a small weight (i.e. 250g block of butter) on the scale and then turning the scale off and then on again with the small weight still on the scale. What this does is to try and re-calibrate the scale. If this doesn't work then I am pretty certain that the scales will need to be replaced. The scales in question do have a 15 year guarantee and you can try contacting Salter Housewares directly if you have your proof of purchase.
https://www.pricescompare.co.uk/q&a/ee-showing-on-screen.html
SOURCE: I have lost my instructions
The scales display EE as they are reading a negative weight.
With the scales switched OFF place 2 glass plates on the scales and press ON.
The scales should now display 0g.
If this doesn't work add more weight and try again.
There is also 4 screws on the underside of the scales which hold the weighing bar in place, if you loosen the 2 smaller screws this should relieve some of the stress so less weight is needed to zero the scales.
SOURCE: Can't open battery case
The middle part slides out. You'll need a small knife or a screwdriver to pry it out gently.
There are openings on two sides. One side has a larger opening than the other. Make sure you pry it out of the lager opening.
Once you gently slide it out, you'll see the two batteries. Make sure the positive side is facing up when you put them back in.
Hope that helps!
SOURCE: my salter 1004SSDR kitchen scale won't show any
Your salter scale has a 15 year warranty. I would call the customer service number 1-866-843-3905 and ask them why it won't zero to weigh anything. They may replace your product.
SOURCE: setting the clock on salter scale model 5007
Hold down the g-oz key and the off key at the same time for about 5 sec's
The hour digit will flash
press the ml-floz key to move the hours.
then press the g-oz key again to move to the minutes.
press the ml-floz key again to set the minutes.
press the g-oz key and it moves to setting the cloak to 12h or 24h option.press the g-oz key to set the time.
And your done.
