Iceing up need help replaceing defrost sensors and main control board
SOURCE: samsung fridge RS2630SH, side by side, icing up on freezer.
You have to pull out the sensor from the board and test with tester, both sensor should read the resistance of 10,000 to 20,000 ohms. The reading that you show is very low it means that the thermistor is out of range and need replacement.
SOURCE: SAMSUNG RB215LASH fridge coil iceing up
first of all everyone needs to get off the idea the heater is not replaceable without breaking into the sealed system.. it is infact replaceable and seperate from the evap coil. you will have to order the whole assembly but the you seperate the front coil/heater from the holders and place it on your unit.. i think tiger direct sells the evap assembly and its around 70 dollars..
SOURCE: Freezer fan noisey. By looks caused by ice.
This would be a failed control board and can sometimes be reset by unplugging the unit for an hour or so...
SOURCE: Samsung model RS2556SH, refrigerator
I have a Samsung fridge model no. RS2556sh. We lost power and when the power came back on the fridge did not. The LED is blinking in the top right corner and the lights or on inside the fridge but not cooling in either side. It doesn't sound like the compresser or any of the fans are coming on. So, what's wrong?
SOURCE: Samsung RS2555SL evaporator is icing
Hi If
refrigerator is not cooling properly it can be due to a defrost timer, which is
causing the fridge to go into defrost cycle. Usually it takes 45-60 minutes for
refrigerator to come out of defrost cycle. If the timer
is bad then it will not come out of defrost cycle and
can result in this kind of issues. It can also occur due to defrost thermostat,
it allows current to pass through it at temperatures of 20 to 30 degrees
Fahrenheit and prevents current from passing through it at 40 to 60 degrees.
This is difficult to test, though, because it takes a prolonged, very-cold
temperature to turn it on. The defrost thermostat is
snapped onto the top portion of the evaporator. The thermostat sends
temperature information to the processor. The defrost heater must be replaced
when replacing the thermostat. Hope this helps...please post back for further
assistance. Daniel
1. Remove the lower fan duct work from the evaporator cover.
2. Remove the 1/4-in. evaporator cover screws and remove the evaporator cover.
3. Disconnect the defrost thermostat wiring connector.
4. Remove the defrost thermostat from the evaporator.
The defrost is not
working.This happens due to the evaporator coil in the inner section of freezer is got
blocked by ice .--------
Try manual defrost reset
procedure: ----
First unplug the unit
from main power outlet. Then empty whole unit completely. Then keep both the
doors open. Wait for 24 hours. All the ice collected on the coils and in the
freezer section will get melted. Clean the water from the sections.
Then Connect the power cord of the unit to main power outlet after 24
hours/.Then set the temperature to normal in both fridge and freezer section.
It will take near to 4 hours to get run in its proper cooling cycle. Then check,
if the problem returns again. If the same problem occurs then it's defrost problem.
The defrost board and the defrost thermostat/heater is not functioning properly
and it has to be checked and replaced.
The procedure of this unit
is as follows: --- The compressor starts then it cools the freezer section.
When the freezer reaches its cooling level the defrost cycle starts functioning.
In this cycle the fan in the freezer section starts running and the cool air in
the freezer section is passed to the refrigerator section and the
refrigerator section gets cold. The air from freezer to refrigerator passes
from the section, in that section the damper is located. Now this problem which
you mentioned. In this problem the freezer thaws, this happens if the
thermostat is not functioning or the heater is not heating. Then the ice starts
getting collected on the evaporator coil. The evaporator coil
is at the internal section of freezer. If too much ice gets collected
then this ice blocks the fan in the freezer section from functioning and this
blocks the damper section with ice getting collected there. This all procedure
is controlled by the defrost board of the unit.
So first try reset procedure.If that is not helping then defrost assembly parts are to be checked and replaced.The defrost thermostat is located in the freezer section beside the evaporator coil.The defrost heater is located in the freezer section beside the evaporator coil.And the defrost control board is located in the fridge section.-------------
you
can get the required parts from online sites like:---
www.repairclinic.com or from searspartsdirect online site.---------This will help.Thanks.Helpmech.
