Dryers Logo
A
Anonymous Posted on Sep 11, 2014
Leaking yellow fluid
Yellow fluid leaking from fron of dryer
Mark Morris
Level 1:
New Friend:
Problem Solver:
  • Contributor 10 Answers
  • Posted on Sep 23, 2014
Mark Morris
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
10
Questions
Helped
2857
Points
10
Dog or cat peed on it. Or liquid is coming from washer. There is no liquid in a dryer to leak out.
Yellow fluid leaking onto serpentine belt
yellow fluid is most likely anti freeze. check the radiator hoses but because of the location, my guess is that it is the water pump leaking. make sure you change the tension pulleys when you change the pump.
Break fluid leaking fron break caliper
you have to replace caliper and bleed line for air,after change.
1helpful
Coolant leak in right fron corner by bottom of head without engine running on 2000 chevy caviliar
headgasket blown, these engine our will known for bad headgaskets, est $800.00 repair
1helpful
Brake lines
Unfortunately you have a fluid leak in the brake system. When you put fluid intry to locate where it is leaking fron
Noticed after parking car there was some fluid leaking fron underneathe the front of the left side of car.
it is probably the breaks fluid is leaking witch is dangerous of losing your breaks power go to the shop now
2answers
Brake pedal goes to the floor under constant presure. New wheel cylinders, vacuum boost, master cylinder, shoes. Everything bled, and no leaks anywhere. Any thoughts?
DID you bleed in this sequence.... Right rear wheel, left rear wheel, right fron wheel, left fron wheel, ABS hydralic fittings, & finally the Master clyinder? If not you will have air in the lines
1helpful
Bought 3 mos ago 1997 Outback Limited Ed, 125k. Auto tranny has developed bad leak, can't find source. Also some fluid seems to be going into Differential as I can take out a QT. Drive a bit and it is...
mcdevito75, The tranny has a front pump to pump fluid back and forth to the torque converter, a seal must be leaking fluid into the diff. also the diff, has tranny fluid in front wheel drive cars so tranny fluid in the diff. is normal, Tranny will have to come out to check that front pump, or fron tranny seal.
Transformation fluid is dripping
Fix leak. Most likely a servo cover leaking. The fluid has to be pumped in fron the bottom of pan until it runs out of fill plug when hot.
OIL PRESSURE GAUGE AND YELLOW FLUID LEAK
isw this leak inside car or outside ,yellow fluid sounds like antifreeze
1helpful
Transmission fluid is leaking
trans pan leak, transcooler lines, trans front seal, trans rear seal, visual inspection is required to properly diagnose
Top Whirlpool Dryers Experts
Virgil Watts
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Eager
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
